[M] - Test linear carriage
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 03/11/2022 at 17:030 Comments
Following the arrival of the nuts and bolts, I've just designed and have started printing the carraige that uses 608 bearings to slide on the 42.4mm tube.
I've added an arc to mitigate flex from PETG, which was the material I was going to print components out of until I started hearing the issues that people building Vorons were having. Ideally, I'd want to print in PBT, but that's a whole other project so I may have to look into other materials.
Hopefully the DP2 can print this without issues, considering this is the first time I'm trying out supports.
