Following the arrival of the nuts and bolts, I've just designed and have started printing the carraige that uses 608 bearings to slide on the 42.4mm tube.
![](https://cdn.hackaday.io/images/2402551647017771938.png)
![](https://cdn.hackaday.io/images/6854821647017772718.png)
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
