[M] - Enclosure Initial Concept
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 03/11/2022 at 23:320 Comments
I should be sleeping, but I've been meaning to model out a basic concept of the frame and enclosure for the SecSavr so that I could get a clue on what it looked like and what panel colours looked the best.
The LED arrangement was a cool idea in my mind, but now I'm concerned that it'll hit the XYZ gantry when it homes. At the same time, just lines on the ceiling would probably be bland.
The middle section is still the same bronze polycarb as the top, it's just that I haven't modelled in any lighting yet. The bottom , as well as all the panels that are not the visible 4 bronze, are Opal.
