![](https://cdn.hackaday.io/images/8099811649162478036.jpg)
The nozzle thermistor doesn't have desirable contact with the nozzle to get an accurate reading.
![](https://cdn.hackaday.io/images/5908311649162657642.jpg)
The CHC took 70s to go from 26C to 236C, and the nozzle took another 40 seconds to equalise at 153C.
![](https://cdn.hackaday.io/images/3879641649163043137.png)
![](https://cdn.hackaday.io/images/3271371649163056440.png)
Then I tried without the melt extenders:
![](https://cdn.hackaday.io/images/6677341649163148074.png)
There was a much larger temperature lag and eventual difference, only reaching 103C.
![](https://cdn.hackaday.io/images/5400501649163298439.png)
![](https://cdn.hackaday.io/images/957691649163309743.png)
Next was a regular volcano nozzle:
![](https://cdn.hackaday.io/images/7266791649163401102.png)
Temp detected at nozzle: 170C
![](https://cdn.hackaday.io/images/4213341649163481735.png)
Lastly, I tested out the supervolcano with 3 9mm extenders (Ideally, I'd just use 1 30mm extender but I'd need to get a suitable M6 tap)
![](https://cdn.hackaday.io/images/7337861649163749109.png)
Temp detected at nozzle: 123C
![](https://cdn.hackaday.io/images/8000011649163814391.png)
TriangleLab's copper melt zone extenders may work better for this application. Regardless, next I will be testing out the flow rates in a future Project Log.
