Current Motor Layout Plan
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 04/12/2022 at 07:581 Comment
From asking around, and research, it sounds like Klipper might run into issues with the dual MCU setup I'd need. This is becuase boards like the RPi (and I assume the Orange Pi) are not realtime.  The main concern is the dual ZM (main z gantry) axis, which ideally should move at the same time.
This is what I'm currently planning:
  1. Octopus Pro
    1. X1
    2. Y1
    3. ZM
    4. ZM
    5. W1
    6. V1
    7. E1
    8. S1
  2. Octopus Pro
    1. X2
    2. Y2
    3. Z1
    4. Z2
    5. W2
    6. V2
    7. E2
    8. S2
Where
Daniel Grace wrote 04/12/2022 at 19:39 point
Yes, there are a few limitations in klipper with multi-mcu setups. I know that paired motors are supposed to be on the same MCU. I believe that it's recommended for limit switches to sit on the same MCU as the motors they control, as well. ie, your X end stop should be on the same mcu as your X motor(s). You might want to double check that one, but I'm pretty sure.
