This project demonstrated how to apply a simple machine learning model trained via Google TensorFlow, and transfer it to AMB21/22/23 board
Connect the microphone and LEDs to the AMB21/22 board following the diagram.
As AMB23 has a built-in microphone on the board, there is no need for any external microphone. For the LEDs, we will only connect two LEDs and then use the two onboard LEDs (Blue and Green).
