So we are going a little more extravagant with the styling of the board this time. It will focus more on the artistic side of things than the technical side.
We will be striving to make the badge look good. Really good. But still functional.
So the functional stuff...
The goal is to make it a simple MP3 player that uses the mask part to display VUs and equalizer bars (and a bunch of Daft Punk helmet-related stuff). The badge will be able to play MP3s from an SD card and output the audio to a headphone jack, speakers, or bluetooth (hopefully).
One other possible addition, if we have time and cpu cycles, will be some kind of digitizing and mixing of a microphone input so the owner can sing along.
Planning to use the ESP32 for all the processing and controlling the LEDs. Using the good ol' ws2812b 2020s, 5ma version. And a pair of MAX98357A for the audio amps. Figuring out what speakers we want to use on the badge still. Should we assume most people won't expect to have good audio from built-in speakers and just use the bluetooth or headphones, or should we go for higher quality audio...
hexum064
CircuitMonster
Piotr Esden-Tempski
stupid
well this is cool :) next you should build this as a Mask ;)
