1Step 1
First I made the electric contacts for the headphones. For that I used copper tape.
First I applied it on the top; then I did several cuts, spaced 1 centimeter each, and bent them to form an electrode in the lateral. It doesn't touch my head because the headband has a piece of foam.
2Step 2
To avoid problems with the polarity, I added a diode bridge. Unfortunately, that meant that the output voltage would be about 1.4 volts less that the input, so I also added a voltage regulator. This allowed me to use a 12 volts power supply while feeding 5 volts to the headphones charger.
3Step 3
The next step was to design a support where to hang the headphones with two electrodes that would make contact with the headband. I used FreeCAD for that.
The file can be downloaded from the gitlab repository.
4Step 4
After printing it, I covered the tabs with copper tape.
5Step 5
Then passed the power supply cables through the holes in the base and soldered them to the tabs.
6Step 6
Finally, I used some hot glue to ensure that everything was kept in place.
7Step 7
And this is the final result: now my headphones are always charged and ready to be used.
Sergio Costas
I would love to see the wiring on the headset itself. How did you manage to fit all that inside the headset?
