• 1
    Introduction
    As RTL8722DM MINI has a built-in microphone on the board, there is no need for any external microphone. Copy a sample wav file into the MicroSD card for demo. (In this example, the sample name is “Test_Audio_48khz_16bit_stereo.wav”. ) Then insert the MicroSD card into the adapter at the back of the board.
    1
  • 2
    ​Example 01 PlaybackWavFile
    Open the example, “Files” -> “Examples” -> “AmebaAudioCodec” -> “PlaybackWavFile”.
    1Upload the code and press the reset button on Ameba once the upload is finished.
    Insert earphones/speakers into the onboard jack for playing the sample sound.
  • 3
    Example 02 RecordWavFile
    Open the example, “Files” -> “Examples” -> “AmebaAudioCodec” -> “RecordWavFile”.
    1
    Define a GPIO/button(Input high to active) for “RECORDBTN”. Define the “filename[]” for the name of the storge wav file. In this example, the name is “Test_Recording_48khz_16bit_mono.wav”.
    Input high to “RECORDBTN”, then record voice by the onboard mic. When the input is low the record stops. The recorded voice will be stored in “Test_Recording_48khz_16bit_mono.wav” located on a MicroSD card.
