CAN-bus Switch Panel
Build a switch panel to control devices across a CAN-bus system
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
In this project, I designed and built a switch panel as part of my automotive dash board project. The switches control many parts of the project vehicle where a mass of wires would be necessary in a conventional electrical system. Using cheap CAN-bus transceivers, I was able to build a system with only a few wires coming from the switch panels that allows a modular interface to other parts of the electrical system.
