Motor Shield Reprogramming
Create and flash new firmware for the WeMos D1 Mini Motor Shield.
There is a motor shield for the WeMos D1 Mini ESP8266 board, and it uses an STM32F030 microcontroller for the communication. However, the code running on it is really sloppy, resulting in the firmware hanging and bringing the I2C bus down whenever you look at it funny. But we are hackers, we can fix it!
We have pretty good information about the motor shield:
The shield has a serial interface for programming broken out, and that chip is supposed to have a bootloader built-in, so hopefully we will be able to just use stm32flash and an USB2TTL adapter to program it.
There is a nice dev environment template for this family of microcontrollers: https://github.com/szczys/stm32f0-discovery-basic-template
motor_shield.bin
Compiled binary of the new firmware.
octet-stream - 3.04 kB - 05/12/2017 at 13:46
Download
  • Multiple I²C Addresses
    ꝺeshipu11/08/2017 at 10:54 0 comments
    As mentioned by @Matrix User in the comments, the new firmware doesn't support selecting of the I²C address with the jumper pads on the bottom of the board — instead the address is fixed in the firmware. There is an issue reported about this at https://github.com/pbugalski/wemos_motor_shield/issues/3 and some workarounds, including alternate builds of the firmware with different hard-coded addresses.
  • Reprogramming Without Soldering
    ꝺeshipu04/21/2017 at 18:10 8 comments
    Turns out that the procedure in the previous log can be greatly simplified. You don't need an ST-Link programmer, and you don't need to solder anything. Even if your shield is locked, you can unlock and program it with a simple serial adapter. Here is how.
    First, clone the repository:
    $ git clone https://github.com/pbugalski/wemos_motor_shield
    $ cd wemos_motor_shield
    Make sure you have arm-none-eabi-gcc installed, and compile it:
    $ make
    arm-none-eabi-gcc -Wall -g -std=c99 -Os -mlittle-endian -mcpu=cortex-m0 -march=armv6-m -mthumb -ffunction-sections -fdata-sections -Wl,--gc-sections -Wl,-Map=motor_shield.map -Iinc src/startup_stm32.s src/main.c src/user_i2c.c src/tb6612.c -o motor_shield.elf -Tstm32f030.ld
    arm-none-eabi-objcopy -O binary motor_shield.elf motor_shield.bin
    arm-none-eabi-size motor_shield.elf
       text	   data	    bss	    dec	    hex	filename
       2032	   1084	   1056	   4172	   104c	motor_shield.elf
    Now, make sure you have stm32flash utility installed. Short the RTS and the 3V pins on the shield together, like this:
    And the connect the main pins of the shield to your USB2TTL as follows:
    GND ↔ GND
    3V3 ↔ 3V3 (or VCC or whatever it is called on your USB2TTL)
    D2 ↔ TX
    D1 ↔ RX
    and connect it to your computer. Now, see if you can communicate with the device:
    $ stm32flash /dev/ttyUSB0
    stm32flash 0.5
    http://stm32flash.sourceforge.net/
    Interface serial_posix: 57600 8E1
    Version      : 0x31
    Option 1     : 0x00
    Option 2     : 0x00
    Device ID    : 0x0444 (STM32F03xx4/6)
    - RAM        : 4KiB  (2048b reserved by bootloader)
    - Flash      : 32KiB (size first sector: 4x1024)
    - Option RAM : 16b
    - System RAM : 3KiB
    Now, you can unlock your shield:
    $ stm32flash /dev/ttyUSB0 -k
    stm32flash 0.5
    Version      : 0x31
    Option 1     : 0x00
    Option 2     : 0x00
    - Option RAM : 16b
    - System RAM : 3KiB
    Read-UnProtecting flash
    Done.
    $ stm32flash /dev/ttyUSB0 -u
    stm32flash 0.5
    Version      : 0x31
    Option 1     : 0x00
    Option 2     : 0x00
    - Option RAM : 16b
    - System RAM : 3KiB
    Write-unprotecting flash
    Done.
    And now you can flash it:
    $ stm32flash /dev/ttyUSB0 -v -w motor_shield.bin
    stm32flash 0.5
    Using Parser : Raw BINARY
    Version      : 0x31
    Option 1     : 0x00
    Option 2     : 0x00
    - Option RAM : 16b
    - System RAM : 3KiB
    Write to memory
    Erasing memory
    Wrote and verified address 0x08000c2c (100.00%) Done.
    Then disconnect all the wires (including the RTS pin), connect the shield to your WeMos D1 Mini, and it should work.
  • We Have a Fixed Firmware!
    ꝺeshipu04/21/2017 at 17:21 5 comments
    @Piotr Bugalski has recently re-written the firmware for this motor shield, and published it at https://github.com/pbugalski/wemos_motor_shield. From what I can tell, the new firmware is compatible with the old one, minus the hanging and crashing, so it should be perfect for a drop-in replacement.
    Here is how you can flash it to your shield:
    Solder two wires to the first two legs of the microcontroller, counting from the top, like this:
    Be careful to not short them with the legs next to them. This is probably the hardest part.
    Next, connect you ST-Link programmer as follows:
    SWCLK ↔ first wire
    SWDIO ↔ second wire
    GND ↔ GND
    3V3 ↔ 3V3
    T_JRST ↔ RST
    Note that, this is with the shiled *not* connected to the D1 Mini.
    Now, clone the repository:
    Make sure you have installed openocd and arm-none-eabi-gcc. Compile the firmware:
    $ make
    And flash it onto the shield:
    $ make program
    openocd -f stm32f0motor.cfg -f stm32f0-openocd.cfg -c "stm_flash motor_shield.bin" -c shutdown
    Open On-Chip Debugger 0.9.0 (2015-09-02-10:42)
    Licensed under GNU GPL v2
    For bug reports, read
    	http://openocd.org/doc/doxygen/bugs.html
    Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
    adapter speed: 1000 kHz
    adapter_nsrst_delay: 100
    none separate
    srst_only separate srst_nogate srst_open_drain connect_deassert_srst
    Info : Unable to match requested speed 1000 kHz, using 950 kHz
    Info : clock speed 950 kHz
    Info : STLINK v2 JTAG v17 API v2 SWIM v4 VID 0x0483 PID 0x3748
    Info : using stlink api v2
    Info : Target voltage: 3.490340
    Info : stm32f0x.cpu: hardware has 4 breakpoints, 2 watchpoints
    stm_erase
    target state: halted
    target halted due to debug-request, current mode: Thread
    xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffc
    auto erase enabled
    Info : device id = 0x10006444
    Info : flash size = 16kbytes
    target halted due to breakpoint, current mode: Thread
    xPSR: 0x61000000 pc: 0x2000003a msp: 0xfffffffc
    wrote 4096 bytes from file motor_shield.bin in 0.287988s (13.889 KiB/s)
    xPSR: 0x61000000 pc: 0x2000002e msp: 0xfffffffc
    verified 3116 bytes in 0.057512s (52.910 KiB/s)
    shutdown command invoked
    Now, disconnect everything. Your board has the new firmware on it. You can test it, and then desolder the two wires -- you won't be needing them anymore.
  • SWD Programming Continued
    ꝺeshipu11/22/2016 at 20:59 1 comment
    On a quest to configure OpenOCD properly. First of all, the error I'm getting was described in an issue and seems like adding "reset_config none separate" fixes that. I got a new error with this:
    openocd -f extra/fff.cfg -f extra/stm32f0-openocd.cfg -c "stm_flash `pwd`/main.bin" -c shutdown
    none separate
    Info : Target voltage: 3.504912
    none separate
    stm_erase
    target halted due to debug-request, current mode: Handler HardFault
    xPSR: 0xc1000003 pc: 0xfffffffe msp: 0xfffffffc
    auto erase enabled
    Error: stm32x device protected
    Error: failed erasing sectors 0 to 0
    OK, so apparently the chip is write-protected. No problem, we can unlock it with "stm32x unlock 0". After running that, and resetting the chip, I finally got:
    none separate
    Info : Target voltage: 3.506483
    none separate
    stm_erase
    auto erase enabled
    wrote 1024 bytes from file /home/sheep/dev/3rdparty/stm32f0-discovery-basic-template/main.bin in 0.104813s (9.541 KiB/s)
    verified 980 bytes in 0.030723s (31.150 KiB/s)
    Which seems to be a correct flashing.
    All this thanks to advice from @jaromir.sukuba, great thanks!
    Now let's see if I can get a blink example to work...
  • SWD Programming
    ꝺeshipu11/22/2016 at 20:06 0 comments
    Second approach to this is using the SWD protocol with my Chinese ST-Link V2 clone. That requires getting at the SWD pins. Fortunately, they are near the edge of the chip:
    Then I connected it according to the pinout of my programmer (the second one):
    Now just "make program" in that template, and...
    openocd -f /usr/share/openocd/scripts/board/stm32f0discovery.cfg -f extra/stm32f0-openocd.cfg -c "stm_flash `pwd`/main.bin" -c shutdown
    none separate
    Info : Target voltage: 3.497322
    stm_erase
    Error: timed out while waiting for target halted
    TARGET: stm32f0x.cpu - Not halted
    in procedure 'stm_flash'
    in procedure 'reset' called at file "extra/stm32f0-openocd.cfg", line 8
    in procedure 'ocd_bouncer'
    Makefile:72: recipe for target 'program' failed
    make: *** [program] Error 1
    Failure.
    I suspect that I shouldn't be using the configuration for the discovery board, but somehow write my own, however, I can't seem to be able to find any examples...
  • Serial Programming
    ꝺeshipu11/21/2016 at 10:12 1 comment
    Last evening I made the first try at programming this thing. From the datasheet and the schematic it looks straightforward: the BOOT0 pin is connected to the RTC pin of the serial, the NRST pin is connected to DTR, it should just work. So I connected the USB2TTL (also a WeMos one), and gave it a go:
    stm32flash 0.5
    Failed to init device.
    No joy. To the datasheet then! Hmm, they mention a BOOT1 there too, but it's nowhere to be seen as a pin... Let's google for it... http://stackoverflow.com/questions/22351703/stm32f030-and-boot0-pin Ah-ha! It looks like BOOT1 is a flag in something called "user flash option byte", and it has to be set to 0 for the bootloader to start. Shame I have no way to check it.
    If that flag is set to 1 in this firmware, then the only way to reprogram this board is to use an stlink programmer. Fortunately, I do have one! Unfortunately, the SWD and SWC pins are not broken out, so I guess I will need to do some precision soldering directly to the chip's legs. Oh well.
View all 6 project logs
Daniel Oliveira wrote 5 days ago point
Hello all,
Just wondering if someone got the firmware working/building with platformIO.
I gonna try myself but please let me know if you have any hints (newbie here)
ꝺeshipu wrote 5 days ago point
Sorry, I really have no idea about platformio, can't help you there. I don't even understand why you would want to build it with that, when it builds with standard gcc just fine.
trulala wrote 05/23/2018 at 19:46 point
Hi all, thx for the fix. I would like to use ESPeasy with the D1 mini and motorshield. But currently there is no plugin available, only for the Adafruit motor shield. Is anybody able to support me in writing a plugin for ESPeasy?
https://www.letscontrolit.com/forum/viewtopic.php?f=6&t=2844&p=28237#p28237
JackJamesHoward wrote 04/09/2018 at 15:07 point
Does anybody know how to reprogram the STM32F030 to step a stepper motor instead of running two DC motors at a speed.?
janitammi wrote 03/24/2018 at 21:15 point
Profound thank you for this project!
jenya wrote 03/10/2018 at 23:53 point
It Works!
Thanks Man!  awesome patch ;)
igor nakonechnyi wrote 02/17/2018 at 19:55 point
Thank you so much for this manual!
I've got this Chinese clone of Wemos D1 Motor Shield which was not detectable via I2C and thanks to your post I was able to make it work! Unfortunately I was not able to build my own firmware but your built worked perfectly.
Ian Ferguson wrote 11/09/2017 at 14:18 point
Intermittent i2c with new firmware?
First of all, thanks to all of you who've contributed this stuff!
I've been been playing with this for weeks now and I'm going to admit that I'm stuck.
My motor shield seems to be intermittent in its i2c communication.  I've *think* I've managed to upload the new firmware to it (I used the  motor_shield_30.bin binary as I have some problems getting the tool chain to work on my Mac). When I ran the:
stm32flash -v -w motor_shield_30.bin  /dev/cu.usbserial-A400hAYA
command it responded:
Version      : 0x31
Option 1     : 0x00
Option 2     : 0x00
- Option RAM : 16b
- System RAM : 3KiB
Write to memory
Erasing memory
Wrote and verified address 0x08000c20 (100.00%) Done.
I assume that means it worked. Can someone confirm that for me please?
After reassembling the shield and my Wemos, I ran one the i2c scanner sketches but nothing was found.
I followed Matrix User and arn_a's advice and checked the "standby" solder pads on the back of the board. This was very poorly soldered so I re-did it.
Again I reassembled and ran the scanner.  It found a device at 0x30 for several iterations of the scan and then went back to saying "No devices found."
Just for the hell of it, I ran my motor test sketch. Sometimes the motor runs when I tell, sometimes it doesn't - consistent with the i2c comms sometimes working and sometimes not.
I've checked the electrical connections - all seems ok. Looking at i2c pulses on a 'scope suggests that the pulses are 'clean'.
Any ideas on what I'm doing wrong please?
Matrix User wrote 10/08/2017 at 02:33 point
I have two of these on the same circuit. I have soldered the pads on the back side in an attempt to change the I2C address of one so I can use both at the same time. No matter what I do the pads, I can't seem to change the default address. I don't know if this firmware ignores those pads or something else it wrong. Any ideas? Does the following concept still applies to this firmware?
AD1      AD0
–          –         0x2D
–          x         0x2E
x          –         0X2F
x          x          0x30 (défaut)
Matrix User wrote 11/08/2017 at 03:59 point
Matrix User wrote 10/01/2017 at 14:54 point
Actually, I did the steps. The I2C scan sketch can read 0x30 (which it couldn't before). I have applied 12v to VM and GND pins. A1 and A2 has a 12v DC motor attached. I can read 12v using a multimeter across the VM and GND pins but I can't read any voltage on A1/A2 or B1/B2 pins and the motor never spins using the stock Arduino sketch. If I directly apply 12v to the same motor it spins. Any ideas?
Matrix User wrote 10/02/2017 at 09:49 point
Never mind. I read aarn_a comment and seems like this one also had the IO pad soldered for standby mode. I unsoldered it and soldered the I2C pads and everything works now. I didn't think to look there as all documentation said that I2C is standard/default on these boards for standby mode.
Matrix User wrote 10/01/2017 at 04:01 point
Thank you so much guys. I also had a china shield that won't come up in i2c scan sketch. Luckily, I had a serial adapter from a few years ago that I used with Mini Pro. I hooked it up to windows, ran the exe and uploaded the bin in like 2 minutes and it started responding!!
aarn_a wrote 09/19/2017 at 19:54 point
I think your Wemos shield is in IO mode for Standby (see schematic below). Just wire between S and 3.3V to try.
Mine was in that case. I reprogrammed without soldering very easily and it's works now.
srk999 wrote 09/17/2017 at 18:25 point
I was following this tutorial to recycle an RC car (https://diyprojects.io/recycle-remote-controlled-car-rc-car-esp8266-shield-motor-wemos-d1-mini-blynk/). Connected the Wemos D1 mini (https://wiki.wemos.cc/products:d1:d1_mini) to the motor shield (https://wiki.wemos.cc/products:d1_mini_shields:motor_shield). Tested all the connection to see if the motors work when power is supplied to the pins, and they do. But, I cannot make the board send power to the motor shield pins A1, A2, B1, B2 for some reason. VM and GND of the shield are connected to an external 5V power supply (4x1.2V AA). D1 mini is being powered by the USB data cable.
When I connect VM/GND to A1/A2, I see a reaction in the motor, and same goes for the other motor. So, that seems to be working. Now, how do I make the sketch send power to the motors? I'm testing it with the examples from the motor shield library (https://github.com/wemos/WEMOS_Motor_Shield_Arduino_Library).
Eliot wrote 09/14/2017 at 21:00 point
The schematic link above is broken, and the wemos wiki for this board links to the relay shield!.
Here is one I found.  Original PDF anybody?
ꝺeshipu wrote 09/17/2017 at 10:17 point
Apparently they are reorganizing their website from time to time and breaking all the links. Perhaps archive.org will have it.
Eliot wrote 09/14/2017 at 07:27 point
Thanks for this! Certainly makes the shield usable.   I reprogrammed without any soldering at all.  I just used arduino style jumper wires and poked the pins through the holes in the shield, and then pushed them with my hand to ensure a good contact.  I poked a wire thru the RTS hole and wrapped it round the 3V pin.  The stm32flash operations are very fast, so it is not hard to do.
cr8ive wrote 08/23/2017 at 06:11 point
Those of you who want to do this using Window's 8/10.
Download the motor_shield.bin from above
Download STM32Flash from here https://sourceforge.net/projects/stm32flash/files/
Extract and put the above files into a directory
Plug in your USB serial device and make a note of the COM port it uses
Using Window Command Prompt  cd to the directory
Use the following after connecting the RX,TX,GND,VCC, short the RTS and the 3V as per Radomir Dopieralski instructions on the top of this page .
1) stm32flash.exe COM8 "replace with your port number"
2) stm32flash.exe -k COM8     This will unlock your shield
3) stm32flash.exe -f -v -w motor_shield.bin COM8  this will flash the bin and re-lock the shield.
ꝺeshipu wrote 08/23/2017 at 20:44 point
Thank you for the Windows instructions!
srk999 wrote 09/19/2017 at 00:00 point
Where can we find motor_shield.bin?
EDIT: Found it. It's linked in the post.
caliany wrote 08/01/2017 at 04:04 point
Would you let me know what is your operation system? Linux or Windows?
I have tried it MINGW on windows10 but can't find USBTTY under /dev.
ꝺeshipu wrote 09/17/2017 at 10:18 point
It's Linux of course, under Windows it will come up as COM8 or something like that, depending on your drivers and what USB2TTL you are using.
Allan wrote 06/19/2017 at 16:06 point
I am trying to compile the new code on a raspberry pi but get parameter errors. Can you help.
pi@JMRICBUS:~/wemos_motor_shield $ make arm-none-eabi-gcc -Wall -g -std=c99 -Os -mlittle-endian -mcpu=cortex-m0 -march=armv6-m -mthumb -ffunction-sections -fdata-sections -Wl,--gc-sections -Wl,-Map=motor_shield.map -Iinc src/startup_stm32.s src/main.c src/user_i2c.c src/tb6612.c -o motor_shield.elf -Tstm32f030.ld arm-none-eabi-objcopy -O binary motor_shield.elf motor_shield.bin arm-none-eabi-size motor_shield.elf
make: invalid option -- 'g'
make: invalid option -- '='
make: invalid option -- 'c'
make: invalid option -- '9'
make: invalid option -- 'u'
make: invalid option -- 'a'
make: invalid option -- '6'
make: invalid option -- '-'
make: invalid option -- 'T'
make: invalid option -- '3'
make: invalid option -- '2'
Eliot wrote 09/14/2017 at 20:47 point
I hope you've worked it out by now! But for the record, you need to just issue the "make" command.
All the rest from arm-none-... onwards is what you should see as the OUTPUT of the make command.
Piotr Bugalski wrote 04/18/2017 at 19:32 point
I have an early prototype of new firmware. Original code was never working on my board so I can't really compare the results, but I hope new code is at least not worse than the previous one. You can find my code at: https://github.com/pbugalski/wemos_motor_shield. I2C address selection is not implemented yet and the code is very messy (to fit original style), but hopefully it works as expected. If anyone wants to volunteer some testing I'd be very obligated.
Dzandaa wrote 01/25/2017 at 14:57 point
Is it possible to re-flash the Wemos MotorShield with Keil UVision and the Motor_Shield_Firmware without modifying the board.
what do I need to flash it? (I have USB to ST-LINK and also USB to TTL) how do I connect it to Motor Shield Pins?
Thank you.
Elliot Williams wrote 11/28/2016 at 22:16 point
Following on K.C. and Radomir's ideas to get extra pins:
0) The SWD/SWCLK pins are wired to headers A0, D0.  (Why not?)
1) PA2 is jumpered across to H_STDBY (bottom left pin)
2) The I2C address select pins (AD0/PF0, AD1/PF1) are broken out to D5, D6
Et voila!  Three working GPIOs, while chip can still talk I2C or UART on TX/RX depending on firmware.
Dodgy soldering all around, though.  Wouldn't want to do this too many times.
