Full_capablities.mp4A star is born, everything shown offMPEG-4 Video - 14.77 MB - 11/03/2023 at 03:44 |
Hailey.mp4Singer her verse in closerMPEG-4 Video - 13.58 MB - 11/03/2023 at 03:44 |
Frequency_Sweep.mp4Sweep Entire audio band, and show LED responseMPEG-4 Video - 10.02 MB - 11/03/2023 at 03:43 |
Measured_Frequency_Response.xlsxThe frequency response of each filter (except sub-bass), the corner frequencies, midpoint frequency, and an octave lower and higher than the corner frequenciessheet - 14.62 kB - 11/03/2023 at 03:06 |
sheet - 9.16 kB - 11/03/2023 at 03:06 |
Audio Visualizer.pptxPresentation of the projectpresentation - 4.93 MB - 10/13/2022 at 00:40 |
BOM.xlsxBill of Materialssheet - 67.23 kB - 10/11/2022 at 13:41 |
Trace width vs current.xlsxGraph showing how much current a trace can handle without heating up by more than 10 degrees Celsiussheet - 15.09 kB - 10/11/2022 at 13:41 |
MaxIoOfEachFilterStage.xlsxShows how much current the op amps of each stage of each spectrum filter will output if input signal is above 5Vsheet - 10.62 kB - 10/11/2022 at 13:41 |
LED Driver IC.xlsxDifferences between LED driver simulated in LTSpice and hardware testsheet - 21.79 kB - 10/11/2022 at 13:41 |
FrequencyInformation.xlsxInformation about the decibel scale, volume-voltage range, and frequency spectrum rangessheet - 30.55 kB - 10/11/2022 at 13:41 |
NegativeVoltageMuliplier555.xlsxDifferences between implementing an negative voltage multiplier in LTSpice and on hardwaresheet - 10.86 kB - 10/11/2022 at 13:41 |
