bottom plate of 3D printed case.stlA bottom plate is attached to the PCB for supportStandard Tesselated Geometry - 511.60 kB - 03/28/2022 at 18:53 |
upper plate of 3D printed case.stlAn upper plate is attached to the PCB for supportStandard Tesselated Geometry - 356.82 kB - 03/28/2022 at 18:53 |
Dimension of PCB.pdfThe PCB is used in single-sided PCB. The tracks on the PCB are made using CNC machines and the gerber file "PCB gerber" is accessible in this file sectionAdobe Portable Document Format - 3.53 kB - 03/28/2022 at 18:53 |
x-zip-compressed - 8.80 kB - 03/28/2022 at 18:53 |
3D view of the PCB.pdf3D view of PCB for better understanding of the finished PCB. The banana pinhead (plug) is cut and the back portion of the pin is soldered to the PCB.Adobe Portable Document Format - 3.53 kB - 03/28/2022 at 18:53 |
