Accident
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 16:120 Comments
I've not been careful enough ! It was nearly over, only half a millimeter,  I turned it on the vise, and it was a bad idea, it broke at first attempt.
