The remaining 3 or 4 mm must be carefully filled.
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 16:080 Comments
It will take time, hand filling is long, but I don't trust my routing skills enough.
