Testing Success and Data-Logger Code
A project log for Trick Tracker
ESP32 based data-logger for 9-Axis Accelerometer and Pressure
MirkoMirko 12/01/2022 at 13:060 Comments
Testing was successfully done!
The SD-Card Holder is pretty shitty and already kind of broke after a few times in and out. I created a 3D case which is about to be printed. With that case I can attach the device via the Wahoo connector to any bike.
I also wrote the code for data-logging to write the sensor data to the SD-Card. With this setup I can go out and collect data of different jumps and tricks on a bike which I then can throw into some TinyML processing tool like Edge Impulse or similar.
I still need to lean about machine learning on microntrollers.
