So after a short revision of the existing code i added two new functions just for fun.
You can find them here:
https://gist.github.com/Stefan-Xp/e0cd595200d31ee6518c (Forked from DaveDarko)
I would love to get some feedback ;)
Next: Create some nice animations :D With a 3x3x3 Cube how many different "frames" could be created before repeating? ;)
Stefan-Xp
A cool add-on would be integer arrays instead of boolean arrays, to integrate fading into animations.
Does it fade to fast or to slow?
What do you mean by "fade between values"?
That would indeed be cool ^^
I meant something like fade_between(64,127) and it only fades between 64 and 127 up and down, but I guess that's what you've build. Not sure why it wont work on my board. Atmega8 fail? Looks like the same way my code works... strange.
Try a bigger Steps Value?
Its a bit strange...
BTW... did you see this remark: "A boolean holds one of two values, true or false. (Each boolean variable occupies one byte of memory.)" ? So we could also use Byte instead for animations, which would give up to 254 Brightness Levels.
Never noticed that it takes a byte, too. Thought the compiler would do some magic with bits in eight bytes. Well then, why not, lets use byte :D
But In my case I'm using npn transistors to drive the layers - so the layer is active when High.
Btw: I just updated the SW.
I changed it a bit to;
byte mode=1;
void loop() {
//// select one
//mode = random(8);
//mode = 1;
mode++;
I calculated 168mA per Layer as worst case.
BTW: http://subethasoftware.com/2013/04/09/arduino-compiler-problem-with-ifdefs-solved/ => Now it works how its supposed.
Perhapps the Cathode High and Low definitions can also go into those #ifdef statements.
And i shrinked the programm from 5.242 Byte to 5130 by replacing the integer Pins with defines.
I don't have any problems switching those values :)
But I think there are some issues with the count of frames...
Feel free to test it ;)
