1Arduino IDE board installation
Add this following line to the "Additional Board Manager URLs",
Then install Ameba D (BW16) package from the board manager
2Upload the code
Use Arduino IDE to upload the code (available on Github) to Ameba BW16
3Assemble the component
3D print the case and base then use hot glue to secure both the encoder and the BW16 dev board to the base, connect pin 8 of BW16 board to the encoder switch pin and Vcc to encoder's GND
4Pair BW16 Bluetooth HID Keyboard to your PC
Upon powering up, your PC will be able to find a bluetooth keyboard named "AMEBA_BLE_HID", connect to it and your PC will automatically re-connect to it everytime it become discoverable
5Install TheFuck package to your PC
SimonXi
