UDP test client.pyTo send UDP message from another machine connected to WiFi network to ESPx-python - 251.00 bytes - 12/18/2016 at 01:41 |
ESP8266-ULN2003-driver-v1-2.forthAdded handler for WiFi. Now accepts command lines from UDP connection.forth - 4.01 kB - 12/18/2016 at 01:38 |
ESP8266-ULN2003-driverv1-0-uncommented.forthRemoved comments just speeds up loading slightly, plus shows how little code is really needed. It is still 1098 bytes in the file, so maybe a few more comments and whitespace need to go just to get it under 1K bytes of source code!forth - 1.07 kB - 12/07/2016 at 12:53 |
ESP8266-ULN2003-driver-v1-0-tests.forthKept the comments and the tests in here. Usually just copy the relevant test line into the serial monitor as needed.forth - 1.96 kB - 12/07/2016 at 12:53 |
ESP8266-ULN2003-driver-v1-0.forthVersion 1.0 with lots of comments, including some tests.forth - 2.90 kB - 12/07/2016 at 12:53 |
