Test tensioner suspension
06/03/2022 at 19:45 • 0 comments -
Body + test leg
06/01/2022 at 13:45 • 0 comments -
Test parts in PLA before buying 5 mm aluminum cutouts
05/30/2022 at 13:50 • 0 comments -
Try a new approach with fewer different parts and a simpler mechanism
05/24/2022 at 12:47 • 0 commentsThe last version was cool, but the cost of the various metal cut parts was insane. I'm trying a new approach with fewer different parts to reduce costs.
Somes big bearing on each axis:
I plan to use tensioners instead of spring suspension. Because find the exact value for the springs is pain.
Here we are, looking good
05/18/2022 at 21:27 • 0 comments -
I broke 2 tap..
05/18/2022 at 21:25 • 0 comments -
Redesign the 3D (again)
05/18/2022 at 21:23 • 0 comments -
More 3D print test
3D print test (it's way too big)
05/18/2022 at 21:22 • 0 comments -
Add somes big spring
05/18/2022 at 21:20 • 0 comments
