This is a spectacularly complex project which builds on itself over time.
As such, this project will be split into smaller sub-projects or milestones to reach.
As of June 2022, these are the first few major milestones that are to be reached:
1. DIY high temperature furnace
2. DIY Ellipsometer for thin film measurements
3. Growing an oxide layer to high accuracy
4. Dopant testing
5. First transistor
6. Thin film deposition in vacuum
6. Silicon based resistors and capacitors
