In this project, we will see the Automatic Room Lights using Arduino and IR Sensor, where the lights in the room will automatically turn ON and OFF by detecting the presence of a human. Such Automatic Room Lights can be implemented in your garages, staircases, bathrooms, etc. where we do not need continuous light but only when we are present. Also, with the help of an automatic room light control system, you need not worry about electricity as the lights get automatically off when there is no person.
Applications
I’ve already mentioned a few applications of the Automatic Room Lights concept. Some of them are:
Garage Lights
Bathroom Lights
Hand Dryers
Toilet Flushers
Security Lights
By following this guide, you will be able to know and make your Automatic Room Light Controller. This project guide contains the files necessary to help you step by step produce your own Automatic Room Light Controller. Please follow the steps of the project to get a positive result.
Step 1:- Get your PCB ready!
Talking about electronics
After making the circuit diagram I transformed it into a PCB design to produce it, to produce the PCB, I have chosen JCLPCB the best PCB supplier and the cheapest PCB provider to order my circuit. with the reliable platform, all I need to do is some simple clicks to upload the Gerber file and set some parameters like the PCB thickness color and quantity. I’ve paid just 2 Dollars to get my PCB after five days only, what I have noticed about JCLPCB this time is the "out-of-charge PCB color" which means you will pay only 2 USD for any PCB color you choose.
2
Get all the Components Listed below images.
3
Place all the components on PCB and solder it properly.
