JPEG Image - 2.52 MB - 06/14/2022 at 22:03 |
keyset.kicad_pcbPCB source for KICADx-kicad-pcb - 95.79 kB - 06/14/2022 at 13:19 |
keyset.schSchematic source for KICADx-kicad-schematic - 3.77 kB - 06/14/2022 at 13:19 |
augment-cuecard-keyset.jpegDoug's button to keycode mapping from the Augment project.JPEG Image - 1.83 MB - 06/14/2022 at 13:18 |
engelbart.inoSource code, much of which is from the USB host Teensy code written by Paul Stoffregen.x-arduino - 12.52 kB - 06/14/2022 at 13:18 |
engelbart-piano-key-spacer.scadTwo of these center the keys in the case, one on each end.x-openscad - 629.00 bytes - 06/14/2022 at 13:14 |
engelbart-piano-key-spacer.stlTwo of these center the keys in the case, one on each end.Standard Tesselated Geometry - 39.73 kB - 06/14/2022 at 13:14 |
engelbart-piano-key.stlFive of these are the keys that press on the switchesStandard Tesselated Geometry - 143.51 kB - 06/14/2022 at 13:14 |
engelbart-piano-key.scadFive of these are the keys that press on the switchesx-openscad - 609.00 bytes - 06/14/2022 at 13:14 |
keyset-topcase.stlKeyset top case. Holds the 3.3mm rod that the keys hinge on.Standard Tesselated Geometry - 170.17 kB - 06/14/2022 at 13:09 |
keyset-botcase.stlKeyset bottom case. Holds the electronics.Standard Tesselated Geometry - 314.12 kB - 06/14/2022 at 13:09 |
keyset-spacers.stlKeyset spacers. Fits between the PCB and topcase.Standard Tesselated Geometry - 98.00 kB - 06/14/2022 at 13:09 |
keyset.scadSource for the case STLs.x-openscad - 4.65 kB - 06/14/2022 at 13:09 |
