1Pry the top off of the candle assembly with a screwdriver (Figure 1).
2Locate the small music PCB and piezoelectric speaker holder.
3Clip the small wires attached to it and release it from the rest of the candle.
4Remove the small wires attached to the battery holder (Figure 2) including the wire connecting both ends of the battery holder.
5Wrap a short length of small gauge solid wire at each end of the battery holder.
6Solder the other ends to the SPDT switch.
