The following is the first version of the prototype.
whole assembly with my feet
![](https://cdn.hackaday.io/images/5819481661525966115.png)
Module Integration with the shoe
The cooler module with insole
![](https://cdn.hackaday.io/images/2032451661525281862.png)
Next time:
- The whole setup was quite bulky, I would try to minimize the size or redistribute everything and make them look nicer.
- The shoe mount is not entirely firm
- The workmanship of the tube bending and the water inlet outlet has to be improved.
- The insole and cooling tank can not be detached easily, which may hinder the maintenance job or fill up the water tank.
- No idea about the water level
