Insole Design
A project log for Footwear Cooler
To develop a water cooler to regulate the temperature of the feet or for some people with hot feet problem
revoxdynaRevoxdyna 08/25/2022 at 14:140 Comments
The insole design was simple.
The cooling pipes run through as much as the area of the feet.
Attach a copper plate to the pipe
However, the cooling area may not be able to extend to the whole feet, and also the flat copper could be designed better to further increase the surface area. Therefore, the copper wires were used instead of the copper plate. As the copper wires were soft, the feet would have better contact with the insole.
The insole was welded and grided.  After testing, the wires were able to deform a little bit to adopt the shape of my feet. I am happy with the design, of course, it can be better and that will be improved next time.
