Modules Used in This Project
A project log for Station_07
This is where i try to integrate everything in one project just for fun.
rfilesRfiles 08/28/2022 at 20:000 Comments
Modules Used In This Project:
HardWare      What I get
BME280Temperature, Pressure, Humidty
ADS11154 channel 15 bit ADC. Channel 4 connected to 3.3V
BH1750Light Intensity
BMP280Temperature, Pressure
CCS811Equivalent CO2, Amount of Volatile Gases
MCP2301716 pin Input/Output Expander
VL53L1Laser Distance Sensor up to 4 meters
VEML6070UV intensity
23LC1024128kB External SPI RAM. Store Values. Pointless for now
WS2812B3 modules full RGB configurable LEDS
MICS68143 Gases Sensor. Uses 3 channels of ADS1115. Measures 8 Gases
MPU92509 Axis Montion Sensor. Accelerometer, Gyroscope, Magnetometer (3 axis each). Also chip temperature
SI1145Light and proximity sensor. Infrared, UltraViolet, Visible, Proximity (With white LED)
VEML6075Ultraviolet Sensor. UVa, UVb, UV intensity
SI7021Temperature, Humidity
TCS34725Light Sensor. Red, Green, Blue, Clear, IR, (LUX, K, CPL calculated)
TCA9548AI2C Switch and level translator for all I2C devices
MLX90614Infrared Temperature Sensor. Object Temperature, Ambient Temperature
SoftWare
What I Get
WiFiWiFi
INFLUXDirect Connection to Database. DOESNT WORK
MQTTSend Data to Nodered in raspberry pi 3B+
OTAAuto check for Update in raspberry pi server, webpage server for update
I2C ScannerScans TCA9548 for devices and lists in Serial Port
