SMT Garden
Step by step instructions for our Learn to Surface Mount Solder board.
Starting from
$19.95
alpenglow has 266 orders / 21reviews
Ships from United States of America
We wanted to make a kit that was specifically for learning how to surface mount solder, and also was a little fun. Thus, the SMT Garden was born! It has ample practice area for many different sizes and types of components from size 1206 all the way down to 0402 if you're looking for a challenge. It also has an active circuit area on the back, all made with very friendly 0805 sized components. Start by practicing diodes and 1206 components in the practice stalks area, then try some 0603s. If you can do those, you're ready for the 0805s in the actual circuit!
Artwork is by Lee Wilkins, @leeborg_
The circuit is of course based on 555 timers, and is an implementation of one on this page, described by homemade-circuits.com:
https://www.homemade-circuits.com/how-to-make-interesting-random-led/
This is our "official" Learn to Surface Mount Solder kit!  It's got a "Practice Stalks" area on the back where you can solder rows of 1206, 0603, and 0402 resistors and capacitors, as well as mini-melf and SOD-323 diodes.  On half of the footprints, one pad is tied to ground, which gives you experience with soldering to pads with some heat sinking.  You might be asking "but what about 0805s?"  Well those are part of the actual circuit!  It's also part of our Fun with 555s series, and uses 2 dual 555 timers and an inverter to create 5 different blink rates, one for each flower.  You can make your flowers whatever color you want (or multicolor!), just be sure to match the LEDs with their corresponding resistor values.  We hope your SMT soldering skills flourish and grow with this cool kit!
The circuit configures all four 555 timers in a circuit called an astable multivibrator.  Basically, it generates a repeating square wave at a particular frequency.  The duty cycle for the square wave is short though, and putting it through the inverter chip not only increases the time that the LED is ON, but also allows the inverter chip to provide the current to drive the LED (555 timers are notoriously poor suppliers of current, especially at low supply voltages).  The fifth frequency is generated by sending 2 of the previous ones through two inverters which are diode-OR'd together.  So it's only off if both of the parent signals are off, and it's brighter when both parent signals are ON.  It gives it a nice flickering effect!
  • 1
    Solder 1206 capacitor and resistor practice stalks
    Gather your supplies.  You'll need:
    • a soldering iron (60W min) set to 700-750F (370-400C)
    • a fine but not sharply pointy tip (0.8mm is good and we prefer bent tips)
    • a flux pen (rosin RMA or water-soluble, most no-clean is not active enough)
    • small diameter solder (0.4mm or below is best)
    • tweezers (we like curved tip ones, but straight work too.  They need to be very pointy to pick up small components.)
    If you need a soldering iron kit with the above supplies, we sell those!
    Flux is very important for surface mount soldering.  You'll be using smaller diameter solder (we like 0.4mm), and it will contain less flux than typical larger-diameter solder.  So the first step before you start to solder is: always coat the pads with flux.
    How to Use Flux:
    We like using a flux pen, as it adds just enough.  The type of flux is also important, most no-clean flux will dissipate way too quickly for easy surface mount work.  We like using rosin RMA (rosin mildly activated) or water-soluble flux.  Water soluble is the best, but you must wash it off with water after you're done.  Keeping it on for days can cause the joints to corrode, and it's also mildly conductive and can wreak havoc with small analog signals.  Rosin RMA flux can be easily removed with 90% isopropyl alcohol, but it's much less aggressive and is often not necessary to clean (though we think clean boards look better, probe better, and make it easier to spot problems!).
    How to Remove Components from Tape:
    Do this over a desk so that your components drop straight to your work surface.  A soldering mat is very handy, especially the ones with small compartments molded in.  Either use a fingernail, or grab your tweezers and insert under the clear tape at the end. Then slowly pull back.  Your components might jump out at this point, that's OK.  Turn the tape over and tap to release all components.
    Note: When soldering the actual circuit, only release the number of parts needed!  This helps you detect mistakes - if you find you have an extra or are one short, you may have soldered a component in the wrong place!
    How to Hold Tweezers:
    When soldering surface mount components, hold the component with tweezers in your non-dominant hand and the soldering iron in your dominant hand.  Getting the hang of how much pressure to use with the tweezers takes a little practice - don't worry if you accidentally fling components across the room at first!  Practice holding a component just above your table with tweezers, and gradually lighten your grip until the component falls to the table.  Do this a few times to get a feel for how light your grip can be.  Ideally, you want to hold a component with just enough force that it doesn't fall out of the tweezers.  We like using curved-tip tweezers, you can use them with either the tips "up" or tips "down", both are shown below.  Tips up can be a more stable way to hold a component, and make it easier at first to place your components flat, but it also requires a lot of component-free space around them, and may be a little less ergonomic.  Eventually, you'll need to get into tight areas, so it's good to get the hang of using the tweezers tips-down.
    How to SMT Solder
    Technique 1 - "Tacking":
    Step 1: Gently hold the component with tweezers and get a small ball of solder on the tip of your iron.  Touch it to the fluxed pad (important that the pad already have flux on it!).  This will create a not-so-great solder joint, but it'll suffice to hold the component in place.
    Step 2: Now solder the other side normally, by holding the solder in your non-dominant hand, and touching it to the iron and the pad simultaneously.  This will create a nicely flowed solder joint.
    Step 3: Add flux to the first not-so-great solder joint with the flux pen.  Reflow the joint with the iron.  Now it should be a nice smooth solder joint
    How to SMT Solder
    Technique 2 - "Blobbing":
    Step 1: Coat one already-fluxed pad in a blob of solder.  (Use one of the non-grounded pads).
    Step 2: While reflowing the solder with one hand, hold the component with tweezers in the other hand and scoot it onto the pad with solder.  Make sure the component is flat, and that there's enough space on the non-soldered pad for the iron tip!
    Step 3: Solder the other pad normally, by holding the solder in one hand, and touching it to the iron and the pad simultaneously.  This will create a nicely flowed solder joint.
    Step 4: Add flux and reflow the first solder joint if needed.
    If you have trouble with solder joints at any time, don't always add more solder!  Try just adding flux, and reflowing them with the iron.
    Soldering GND Pads:
    You might notice that the pads attached to GND are harder to solder!  That's because there's a greater volume of copper attached to these pads, which conducts the heat from the soldering iron away from them.  We have used thermal reliefs on our pads, which is a gap between the solid copper pour and the pad with small traces connecting them.  While these help, you'll still notice a difference when soldering.  Be patient, make sure you're using the side of the tip of the iron (this is the hottest part), and make sure your tip is in good condition.  Flux can also help conduct heat in that first second, as can adding more solder.  Don't worry if you get more solder on these pads at first, or if these joints don't look as good.  Just keep practicing!
    How to Identify a Good Joint:
    A good joint should have just enough solder to create a nice concave "fillet" between the pad and the metallized side of the component.  If yours is convex and blobbly, it's OK as long as it's not in danger of touching (or "bridging" to) a nearby component.
    People make a lot of fuss about leaded solder making nicer joints.  While they are shinier, lead-free solder is much more environmentally friendly, so you might as well get used to it from the start.  All these examples use lead-free solder, and it's not hard to tell a good joint from a bad one.  Note that it's normal for good joints to appear very shiny when the solder is still molten, and then "dull over" as it hardens.
    How to Identify a Bad Joint:
    Bad solder joints can also be referred to as "cold" solder joints.  While lack of heat can cause these, the more frequent cause of "cold" joints is lack of flux.  The flux boils off very quickly when solder is heated with the iron, and oxidation causes the solder to look crystallized, like in the photo.  These joints are both mechanically weaker and have higher resistance.  They often will eventually fail, causing an intermittent open or flaky circuit.  But do not fear, they are super easy to fix!  Just add flux with a flux pen, and reflow the joint.
    SMT Soldering Tips and Tricks:
    • If the board is moving around too much on you, just tape it down to the table.  Eventually, you'll develop enough dexterity to hold the board down with one finger on your non-dominant hand, while holding the component with the tweezers.
    • If you're finding it hard to get the correct angle, don't move your hands to an awkward position, just move or rotate the circuit board!
    • If your hands are shaking - do not fear, mine do too, this is normal!  You can steady your hands by touching the heels of your palms to the surface of the table you're working on.  This stabilizes your entire hand and allows your fingertips to do the more dexterous work of finely positioning the component and soldering iron tip.
    • If you're having trouble with the solder flowing, check a few things.  You can try increasing the temperature, but if you're still having trouble at 750F, it's probably not the temperature.  60W or higher irons are recommended for being able to heat up GND pads.  The very tip of the iron tip is the coldest part, so if your iron tip is extremely sharp, it might not be getting hot enough.  Try a wider one.  Check your solder - formulations with silver (SAC - Sn/Ag/Cu) flow much better than Sn-Cu only formulations.  Your tip may be oxidized - try cleaning it (when cool) with a bit of brass wool.  You can use tip tinner for stubborn tips, but note it will decrease the life of the tip.  Get in the habit of always putting away your tip "dirty" - meaning tinned/coated with solder.  Check the type of flux, use rosin RMA or water-soluble, and add more.
  • 2
    Solder the practice diodes and circuit diodes
    Note: Diodes are directional! be sure to match the line on the footprint to the marking on the component.  The line should always denote the cathode.
    Use the same techniques described above to solder the diodes, and all subsequent components.  We've provided two styles of diodes - the orange glass ones are mini-melf packages, and the black ones with legs are SOD-323 packages.  Other styles with flat or J leads exist too.
    After soldering the SOD-323 diodes to the practice stalk, you can solder the ones that are part of the circuit (D21-D26 shown above).
  • 3
    Solder 0603 capacitor and resistor practice stalks
    Now that you've aced 1206's and diodes, let's jump to smaller 0603 footprints.  These you will likely want magnification for.  Even if you can see them well enough with your bare eyes to solder, you'll still want magnification to fully inspect your joints!  Several different tools can be used: a magnifying glass or magnifying ring light, magnifying head-mounted glasses, or a stereo microscope.  It is more difficult to solder well under a USB camera microscope or a monocular microscope because you lose all depth perception.
    Soldering these is the same process as the above, they're just smaller components.  You might fling them across the room with your tweezers more, practice that just-enough pressure holding.  If you don't have magnification, you can always save these for later and jump to soldering the chips (aka ICs) and the 0805s in the actual circuit.  The 1206s and 0805s are good enough practice to start!
View all 12 instructions
