case freecad files.zipfreecad files for everything. ass_tray1 is the assembly4 file that should load all the rest inx-zip-compressed - 38.15 MB - 09/22/2022 at 13:54 |
case stl files.zipstl files for all the case partsx-zip-compressed - 3.92 MB - 09/22/2022 at 13:53 |
midicontroller PCB kicad.zipi got the pcb made at eurocircuits, no actual mistakes but the leds causing noisy readings is something i'd try to fix if i did this again..x-zip-compressed - 2.16 MB - 09/22/2022 at 13:49 |
MAIN_TRAY.fpdfront panel designer file for the aluminium piece that the motherboard etc screw ontofpd - 1.70 kB - 09/22/2022 at 13:49 |
knobs.zipa couple of different large diameter knob designs. i had to iterate to get a good tight but not too tight fit. printed in clear PLA.x-zip-compressed - 881.79 kB - 09/22/2022 at 13:46 |
midi controller teensy3.2 firmware.zipfirmware for the midi controller board. contains code for reading alpha rv 115 series 360 degree continuous potentiometers which might be useful to someonex-zip-compressed - 19.08 kB - 09/22/2022 at 13:41 |
