1 Intro
The Enecsys Gateway is a Zigbee gateway allowing communications between the Enecsys microinverters and their monitoring backend. The Enecsys company is unfortunately defunct since 2015 and their DNS domains have been taken over by a UK enecsys owner who created his own monitoring system on https://enecsys-monitoring.com/
2 Network interface
boot.pcapng
2.1 Port scans
TCP port scan results for the gateway's IPv4 address:
Starting Nmap 7.80 ( https://nmap.org ) at 2022-08-15 22:08 CEST
Initiating ARP Ping Scan at 22:08
Scanning 10.1.0.10 [1 port]
Completed ARP Ping Scan at 22:08, 0.06s elapsed (1 total hosts)
Initiating SYN Stealth Scan at 22:08
Scannnnning 10.1.0.10 [65535 ports]
Discovered open port 80/tcp on 10.1.0.10
SYN Stealth Scan Timing: About 20.07% done; ETC: 22:11 (0:02:03 remaining)
SYN Stealth Scan Timing: About 41.88% done; ETC: 22:11 (0:01:25 remaining)
SYN Stealth Scan Timing: About 58.10% done; ETC: 22:11 (0:01:06 remaining)
SYN Stealth Scan Timing: About 79.32% done; ETC: 22:11 (0:00:32 remaining)
Completed SYN Stealth Scan at 22:11, 167.83s elapsed (65535 total ports)
Nmap scan report for 10.1.0.10
Host is up, received arp-response (0.0094s latency).
Scanned at 2022-08-15 22:08:48 CEST for 168s
Not shown: 65534 filtered ports
Reason: 65534 no-responses
Some closed ports may be reported as filtered due to --defeat-rst-ratelimit
PORT   STATE SERVICE REASON
80/tcp open  http    syn-ack ttl 100
MAC Address: 34:C6:9A:00:16:D4 (Enecsys)
Read data files from: /usr/bin/../share/nmap
Nmap done: 1 IP address (1 host up) scanned in 168.05 seconds           Raw packets sent: 131198 (5.773MB) | Rcvd: 136 (6.115KB)
UDP port scan results for the gateway's IPv4 address:
Starting Nmap 7.80 ( https://nmap.org ) at 2022-08-15 22:12 CEST
Initiating ARP Ping Scan at 22:12
Completed ARP Ping Scan at 22:12, 0.06s elapsed (1 total hosts)
Initiating UDP Scan at 22:12
Scanning 10.1.0.10 [65535 ports]
UDP Scan Timing: About 2.24% done; ETC: 22:35 (0:22:33 remaining)
UDP Scan Timing: About 4.75% done; ETC: 22:34 (0:21:24 remaining)
UDP Scan Timing: About 8.86% done; ETC: 22:34 (0:20:14 remaining)
UDP Scan Timing: About 13.66% done; ETC: 22:34 (0:19:04 remaining)
UDP Scan Timing: About 18.69% done; ETC: 22:34 (0:17:55 remaining)
UDP Scan Timing: About 23.71% done; ETC: 22:34 (0:16:47 remaining)
UDP Scan Timing: About 28.74% done; ETC: 22:34 (0:15:40 remaining)
UDP Scan Timing: About 33.76% done; ETC: 22:34 (0:14:33 remaining)
UDP Scan Timing: About 40.70% done; ETC: 22:33 (0:13:01 remaining)
UDP Scan Timing: About 45.72% done; ETC: 22:33 (0:11:55 remaining)
UDP Scan Timing: About 50.75% done; ETC: 22:33 (0:10:48 remaining)
UDP Scan Timing: About 55.77% done; ETC: 22:33 (0:09:42 remaining)
UDP Scan Timing: About 60.80% done; ETC: 22:33 (0:08:36 remaining)
UDP Scan Timing: About 65.82% done; ETC: 22:33 (0:07:30 remaining)
UDP Scan Timing: About 70.85% done; ETC: 22:33 (0:06:23 remaining)
UDP Scan Timing: About 76.11% done; ETC: 22:33 (0:05:14 remaining)
UDP Scan Timing: About 81.13% done; ETC: 22:33 (0:04:08 remaining)
UDP Scan Timing: About 86.16% done; ETC: 22:33 (0:03:02 remaining)
UDP Scan Timing: About 91.19% done; ETC: 22:33 (0:01:56 remaining)
UDP Scan Timing: About 96.21% done; ETC: 22:33 (0:00:50 remaining)
Completed UDP Scan at 22:33, 1314.24s elapsed (65535 total ports)
Host is up, received arp-response (0.0027s latency).
All 65535 scanned ports on 10.1.0.10 are open|filtered because of 65535 no-responses
Nmap done: 1 IP address (1 host up) scanned in 1314.44 seconds           Raw packets sent: 131071 (3.676MB) | Rcvd: 74 (4.290KB)
2.2 The Web Interface
The default credentials for the web interface are admin/password. You can tell that the gateway is (c) 2009 as there is no way to change the admin password ;).
The following endpoints have been detected on the device:
Endpoint Description Notes
/index.htm ''
/debug.htm Debug interface HTML layout
/ajax.xml Debug interface polling endpoint
/mpfsupload MPFS Image Upload
2.2.1 Main user interface
The main user interface has basic settings like IP address and it can be used to set the remote monitoring server hostname and port. Apart from that NTP and proxy can be configured. Here is a screenshot of the main UI:
2.2.2 Debug Interface
The debug interface allows us to see what messages the Zigbee Module UART sends to the main MCU. These appear to be raw decrypted contents of Zigbee frames from the inverters as well as some traffic generated by the Zigbee module firmware itself even when there are no inverters connected. Some of the layout of these messages has been reverse engineered in the section near the end of the document. There is also a status display about the Zigbee network and monitoring server connection. The interface itself looks like this:
The debug UI polls the /ajax.xml endpoint in the background in order to receive the data about the latest messages received from the Zigbee module. The endpoint returns the following XML:
#+BEGINajaxxml <response> <zigbeeData></zigbeeData> <serverData></serverData> <connectionStatus>Offline</connectionStatus> <connectionUptime>-NA-</connectionUptime> <lastConnectionUptime>000:00:00</lastConnectionUptime> <connectionUptimeSinceReset>000:00:00</connectionUptimeSinceReset> <totalConnects>0</totalConnects> <connectionDowntime>000:23:21</connectionDowntime> <lastConnectionDowntime>-NA-</lastConnectionDowntime> <connectionDowntimeSinceReset>000:23:21</connectionDowntimeSinceReset> <timeSinceReset>000:23:21</timeSinceReset> <devicesInNetwork>0</devicesInNetwork> <device0></device0> <device1></device1> <device2></device2> <device3></device3> <device4></device4> <device5></device5> <device6></device6> <device7></device7> <device8></device8> <device9></device9> <device10></device10> <device11></device11> <device12></device12> <device13></device13> <device14></device14> <device15></device15> <device16></device16> <device17></device17> <device18></device18> <device19></device19> <device20></device20> <device21></device21> <device22></device22> <device23></device23> <device24></device24> <device25></device25> <device26></device26> <device27></device27> <device28></device28> <device29></device29> <device30></device30> <device31></device31> <device32></device32> <device33></device33> <device34></device34> <device35></device35> <device36></device36> <device37></device37> <device38></device38> <device39></device39> <device40></device40> <device41></device41> <device42></device42> <device43></device43> <device44></device44> <device45></device45> <device46></device46> <device47></device47> <device48></device48> <device49></device49> <device50></device50> <device51></device51> <device52></device52> <device53></device53> <device54></device54> <device55></device55> <device56></device56> <device57></device57> <device58></device58> <device59></device59> <device60></device60> <device61></device61> <device62></device62> <device63></device63> <device64></device64> <device65></device65> <device66></device66> <device67></device67> <device68></device68> <device69></device69> <device70></device70> <device71></device71> <device72></device72> <device73></device73> <device74></device74> <device75></device75> <device76></device76> <device77></device77> <device78></device78> <device79></device79> <device80></device80> <device81></device81> <device82></device82> <device83></device83> <device84></device84> <device85></device85> <device86></device86> <device87></device87> <device88></device88> <device89></device89> <device90></device90> <device91></device91> <device92></device92> <device93></device93> <device94></device94> <device95></device95> <device96></device96> <device97></device97> <device98></device98> <device99></device99> </response> #+ENDpacket
2.2.3 The MPFS upload
The MPFS is an internal HTTP upload server enabled by default in the Microchip TCP/IP stack. This feature can be used to upload files into the internal flash and possibly even modify firmware. There has been at least one device where this is possible: https://vulners.com/talos/TALOS-2018-0511. In the case of our device this won't be much use however as all of the Zigbee traffic encryption happens in the Zigbee module and the Microchip MCU is just a simple bridge which forwards the messages to the remote monitoring server.
3 Zigbee Radio
The gateway contains a ETRX2-PA Zigbee module manufactured by Telegesis. More information about this module can be found in the page describing the Enecsys SMI-360-72 Inverter. When the gateway boots and initializes its radio interfaces it starts to send broadcast frames every 15 seconds:
No.     Time           Source                Destination           Protocol Length Info      1 0.000000       0x0000                Broadcast             ZigBee   47     Command, Dst: Broadcast, Src: 0x0000
Frame 1: 47 bytes on wire (376 bits), 47 bytes captured (376 bits) on interface -, id 0    Interface id: 0 (-)    Encapsulation type: IEEE 802.15.4 Wireless PAN (104)    Arrival Time: Sep 21, 2022 20:43:42.000000000 CEST    [Time shift for this packet: 0.000000000 seconds]    Epoch Time: 1663785822.000000000 seconds    [Time delta from previous captured frame: 0.000000000 seconds]    [Time delta from previous displayed frame: 0.000000000 seconds]    [Time since reference or first frame: 0.000000000 seconds]    Frame Number: 1    Frame Length: 47 bytes (376 bits)    Capture Length: 47 bytes (376 bits)    [Frame is marked: False]    [Frame is ignored: False]    [Protocols in frame: wpan:zbee_nwk:data]
IEEE 802.15.4 Data, Dst: Broadcast, Src: 0x0000    Frame Control Field: 0x8841, Frame Type: Data, PAN ID Compression, Destination Addressing Mode: Short/16-bit, Frame Version: IEEE Std 802.15.4-2003, Source Addressing Mode: Short/16-bit    Sequence Number: 227    Destination PAN: 0x0064    Destination: 0xffff    Source: 0x0000    [Extended Source: Enecsys_00:77:35:c1:a9 (34:c6:9a:00:77:35:c1:a9)]    [Origin: 1]    FCS: 0xd8bc (Correct)
ZigBee Network Layer Command, Dst: Broadcast, Src: 0x0000    Frame Control Field: 0x1209, Frame Type: Command, Discover Route: Suppress, Security, Extended Source Command    Destination: 0xfffc    Source: 0x0000    Radius: 1    Sequence Number: 23    Extended Source: Enecsys_00:77:35:c1:a9 (34:c6:9a:00:77:35:c1:a9)    ZigBee Security Header    Data (2 bytes)
0000  9c 39                                             .9
Frame 2: 47 bytes on wire (376 bits), 47 bytes captured (376 bits) on interface -, id 0    Interface id: 0 (-)    Encapsulation type: IEEE 802.15.4 Wireless PAN (104)    Arrival Time: Sep 21, 2022 20:43:58.070981000 CEST    [Time shift for this packet: 0.000000000 seconds]    Epoch Time: 1663785838.070981000 seconds    [Time delta from previous captured frame: 16.070981000 seconds]    [Time delta from previous displayed frame: 16.070981000 seconds]    [Time since reference or first frame: 16.070981000 seconds]    Frame Number: 2    Frame Length: 47 bytes (376 bits)    Capture Length: 47 bytes (376 bits)    [Frame is marked: False]    [Frame is ignored: False]    [Protocols in frame: wpan:zbee_nwk:data]
IEEE 802.15.4 Data, Dst: Broadcast, Src: 0x0000    Frame Control Field: 0x8841, Frame Type: Data, PAN ID Compression, Destination Addressing Mode: Short/16-bit, Frame Version: IEEE Std 802.15.4-2003, Source Addressing Mode: Short/16-bit    Sequence Number: 228    Destination PAN: 0x0064    Destination: 0xffff    Source: 0x0000    [Extended Source: Enecsys_00:77:35:c1:a9 (34:c6:9a:00:77:35:c1:a9)]    [Origin: 1]    FCS: 0x6a0b (Correct)
ZigBee Network Layer Command, Dst: Broadcast, Src: 0x0000    Frame Control Field: 0x1209, Frame Type: Command, Discover Route: Suppress, Security, Extended Source Command    Destination: 0xfffc    Source: 0x0000    Radius: 1    Sequence Number: 24    Extended Source: Enecsys_00:77:35:c1:a9 (34:c6:9a:00:77:35:c1:a9)    ZigBee Security Header    Data (2 bytes)
0000  37 38                                             78
Some more beacons can be found in gateway-beacon.txt. Unfortunately the beacons are encrypted with an unknown Zigbee Network key. This key is likely preconfigured as it would make sense for such a closed-loop system. Trying to decrypt the messages using the typical Zigbee key used by the Home Automation Profile (0x5A 0x69 0x67 0x42 0x65 0x65 0x41 0x6C 0x6C 0x69 0x61 0x6E 0x63 0x65 0x30 0x39) does not work.
As for the inverter, when it boots it first sends out a standard Beacon Request Zigbee packet every 77 (sic!) seconds, see traffic inverter-beacon.txt:
No.     Time           Source                Destination           Protocol Length Info      1 0.000000                             Broadcast             IEEE 802.15.4 10     Beacon Request
Frame 1: 10 bytes on wire (80 bits), 10 bytes captured (80 bits) on interface -, id 0
IEEE 802.15.4 Command, Dst: Broadcast    Frame Control Field: 0x0803, Frame Type: Command, Destination Addressing Mode: Short/16-bit, Frame Version: IEEE Std 802.15.4-2003, Source Addressing Mode: None    Sequence Number: 81    Destination PAN: 0xffff    Destination: 0xffff    Command Identifier: Beacon Request (0x07)    FCS: 0x6d72 (Correct)
No.     Time           Source                Destination           Protocol Length Info      2 77.003990                            Broadcast             IEEE 802.15.4 10     Beacon Request
Frame 2: 10 bytes on wire (80 bits), 10 bytes captured (80 bits) on interface -, id 0
IEEE 802.15.4 Command, Dst: Broadcast    Frame Control Field: 0x0803, Frame Type: Command, Destination Addressing Mode: Short/16-bit, Frame Version: IEEE Std 802.15.4-2003, Source Addressing Mode: None    Sequence Number: 97    Destination PAN: 0xffff    Destination: 0xffff    Command Identifier: Beacon Request (0x07)    FCS: 0xaaa2 (Correct)
No.     Time           Source                Destination           Protocol Length Info      3 154.014790                           Broadcast             IEEE 802.15.4 10     Beacon Request
Frame 3: 10 bytes on wire (80 bits), 10 bytes captured (80 bits) on interface -, id 0
IEEE 802.15.4 Command, Dst: Broadcast    Frame Control Field: 0x0803, Frame Type: Command, Destination Addressing Mode: Short/16-bit, Frame Version: IEEE Std 802.15.4-2003, Source Addressing Mode: None    Sequence Number: 113    Destination PAN: 0xffff    Destination: 0xffff    Command Identifier: Beacon Request (0x07)    FCS: 0xe812 (Correct)
After receiving an answer to the Beacon Request from the gateway the standard association process starts. This has been captured and is available in zigbee-inverter-connect.pcapng and inverter-associate.txt as a text dump. After the exchange of some data back and forth the gateway indicates that the inverter is connected by incrementing a counter on the LCD.
4 Zigbee Messages Format
A number of messages have been captured so far when the device and inverter were in various operational modes. Based on the knowledge gained the development of a parser for the messages has been started: enecsys-watch-zigbee.py
WZ=qcE1dwCaxjQAAAZhIQEAAAAMClP1BfcFAJrGNEg=AE,S=2000011689 sent when inverter connects
00000000  a9 c1 35 77 00 9a c6 34  00 00 07 51 21 01 00 00  |..5w...4...Q!...|
00000010  00 0f 0a 53 f5 05 f7 05  00 9a c6 34 48           |...S.......4H|
0000001d
the first 8 bytes are the gateway Zigbee MAC address (34:c6:9a:00:77:35:c1:a9)
next we get some data and then the inverter MAC address (34:c6:9a:00:05:f7:05:f5)
WZ=qcE1dwCaxjQAAAaSIQEAAAAOClOpwTV3AJrGNEg=0E,S=2000011689 these are from the gateway itself
00000000  a9 c1 35 77 00 9a c6 34  00 00 06 92 21 01 00 00  |..5w...4....!...|
00000010  00 0e 0a 53 a9 c1 35 77  00 9a c6 34 48           |...S..5w...4H|
0000001d
This one is different, we don't have the inverter MAC but something else
inverter serial on barcode
01 00 04 50 29 (dec)
01 00 04 32 1d (hex)
inverter serial on label
00 00 61 75 77 (dex)
00 00 3d 4b 4d (hex)
WS=9QX3BQCaxjQAAAbLIQEAAAAAFDADiAEAAgAAAAAAAAAYAY0AAwQF00  00000000  f5 05 f7 05 00 9a c6 34  00 00 06 cb 21 01 00 00  |.......4....!...|
00000010  00 00 14 30 03 88 01 00  02 00 00 00 00 00 00 00  |...0............|
00000020  18 01 8d 00 03 04 05                              |.......|
00000027
First 8 bytes are the MAC address of the inverter (34:c6:9a:00:05:f7:05:f5), later we have something that appears to be data from the inverter
WZ=qcE1dwCaxjQAAAdRIQEAAAAPClP1BfcFAJrGNEg=60,S=2000011689
0000001d
WS=9QX3BQCaxjQAAAdYIQIAAAAAFDADiAEAAgAAAAAAAAAZAY0AAwAF81
00000000  f5 05 f7 05 00 9a c6 34  00 00 07 58 21 02 00 00  |.......4...X!...|
00000020  19 01 8d 00 03 00 05                              |.......|
00000027
WS=9QX3BQCaxjQAAAdYIQIAAAAAFDADiAEAAgAAAAAAAAAZAY0AAwAF81  << these seem to come from the inverter
00000027
WS=9QX3BQCaxjQAAAe7IQEAAAACFDADiAEAAgAAAAAAADgZAY0AAwAF44
00000000  f5 05 f7 05 00 9a c6 34  00 00 07 bb 21 01 00 00  |.......4....!...|
00000010  00 02 14 30 03 88 01 00  02 00 00 00 00 00 00 38  |...0...........8|
00000027
WS=9QX3BQCaxjQAAAkkIQEAAAAFFDADiAEAAgAAAAAAADgZAY0AAwAF8A
00000000  f5 05 f7 05 00 9a c6 34  00 00 09 24 21 01 00 00  |.......4...$!...|
00000010  00 05 14 30 03 88 01 00  02 00 00 00 00 00 00 38  |...0...........8|
00000027
WZ=qcE1dwCaxjQAAAkyIQEAAAATClP1BfcFAJrGNEg=7A,S=2000011689
00000000  a9 c1 35 77 00 9a c6 34  00 00 09 32 21 01 00 00  |..5w...4...2!...|
00000010  00 13 0a 53 f5 05 f7 05  00 9a c6 34 48           |...S.......4H|
0000001d
WZ=qcE1dwCaxjQAAAljIQEAAAAUClOpwTV3AJrGNEg=E9,S=2000011689
00000000  a9 c1 35 77 00 9a c6 34  00 00 09 63 21 01 00 00  |..5w...4...c!...|
00000010  00 14 0a 53 a9 c1 35 77  00 9a c6 34 48           |...S..5w...4H|
0000001d
WS=9QX3BQCaxjQAAAoUIQEAAAAHFDADiAEAAgAAAAAAADgaAY0AAwAF5B
00000000  f5 05 f7 05 00 9a c6 34  00 00 0a 14 21 01 00 00  |.......4....!...|
00000010  00 07 14 30 03 88 01 00  02 00 00 00 00 00 00 38  |...0...........8|
00000020  1a 01 8d 00 03 00 05                              |.......|
00000027
WZ=qcE1dwCaxjQAAAoiIQEAAAAVClP1BfcFAJrGNEg=22,S=2000011689
WZ=qcE1dwCaxjQAAApTIQEAAAAWClOpwTV3AJrGNEg=BD,S=2000011689
WS=9QX3BQCaxjQAAAqMIQEAAAAIFDADiAEAAgAAAAAAADgaAY0AAwAF44
WS=9QX3BQCaxjQAAAsEIQEAAAAJFDADiAEAAgAAAAAAADgaAY0AAwAF1E
WZ=qcE1dwCaxjQAAAz0IQEAAAAbClP1BfcFAJrGNEg=C9,S=2000011689
WZ=qcE1dwCaxjQAAA0lIQEAAAAcClOpwTV3AJrGNEg=BC,S=2000011689
WS=9QX3BQCaxjQAAA3WIQEAAAAPFDADiAEAAgAAAAAAADgaAY0AAwAFCF
WZ=qcE1dwCaxjQAAA4VIQEAAAAeClOpwTV3AJrGNEg=A0,S=2000011689
WS=9QX3BQCaxjQAAA5OIQEAAAAQFDADiAEAAgAAAAAAADgaAY0AAwAF9D
WS=9QX3BQCaxjQAAD2_IQEAAAB1FDADiAEAAgAAAAAAADgdAY0AAwAF46
WZ=qcE1dwCaxjQAAD6-IQEAAACFClP1BfcFAJrGNEg=48,S=2000011689
Vdc = 36V
36 dec == 24 hex
WS=9QX3BQCaxjQAAEs1IQEAAAALFDADiAMAAgAAAAAAADgdAY4AAwAFCB
00000000: F5 05 F7 05 00 9A C6 34  00 00 4B 35 21 01 00 00  .......4..K5!...
00000010: 00 0B 14 30 03 88 03 00  02 00 00 00 00 00 00 38  ...0...........8
00000020: 1D 01 8E 00 03 00 05                              .......
WS=9QX3BQCaxjQAAEuuIQEAAAAMFDADiAMAAgAAAAAAADgdAY4AAwAF2E
00000000: F5 05 F7 05 00 9A C6 34  00 00 4B AE 21 01 00 00  .......4..K.!...
00000010: 00 0C 14 30 03 88 03 00  02 00 00 00 00 00 00 38  ...0...........8
Vdc = 42V 42 dec == 2a hex
WS=9QX3BQCaxjQAAE0WIQEAAAAPFDADiAMAAgAAAAAAAEUdAY4AAwAF29
00000000: F5 05 F7 05 00 9A C6 34  00 00 4D 16 21 01 00 00  .......4..M.!...
00000010: 00 0F 14 30 03 88 03 00  02 00 00 00 00 00 00 45  ...0...........E
WS=9QX3BQCaxjQAAE2OIQEAAAAQFDADiAMAAgAAAAAAAEUdAY4AAwAFE5
00000000: F5 05 F7 05 00 9A C6 34  00 00 4D 8E 21 01 00 00  .......4..M.!...
00000010: 00 10 14 30 03 88 03 00  02 00 00 00 00 00 00 45  ...0...........E
WS=9QX3BQCaxjQAAE4HIQEAAAARFDADiAMAAgAAAAAAAEUdAY4AAwAFE1
00000000: F5 05 F7 05 00 9A C6 34  00 00 4E 07 21 01 00 00  .......4..N.!...
00000010: 00 11 14 30 03 88 03 00  02 00 00 00 00 00 00 45  ...0...........E
