1 Intro
The Enecsys Gateway is a Zigbee gateway allowing communications between the Enecsys microinverters and their monitoring backend. The Enecsys company is unfortunately defunct since 2015 and their DNS domains have been taken over by a UK enecsys owner who created his own monitoring system on https://enecsys-monitoring.com/
2 Network interface
boot.pcapng
2.1 Port scans
TCP port scan results for the gateway's IPv4 address:
Starting Nmap 7.80 ( https://nmap.org ) at 2022-08-15 22:08 CEST
Initiating ARP Ping Scan at 22:08
Scanning 10.1.0.10 [1 port]
Completed ARP Ping Scan at 22:08, 0.06s elapsed (1 total hosts)
Initiating SYN Stealth Scan at 22:08
Scannnnning 10.1.0.10 [65535 ports]
Discovered open port 80/tcp on 10.1.0.10
SYN Stealth Scan Timing: About 20.07% done; ETC: 22:11 (0:02:03 remaining)
SYN Stealth Scan Timing: About 41.88% done; ETC: 22:11 (0:01:25 remaining)
SYN Stealth Scan Timing: About 58.10% done; ETC: 22:11 (0:01:06 remaining)
SYN Stealth Scan Timing: About 79.32% done; ETC: 22:11 (0:00:32 remaining)
Completed SYN Stealth Scan at 22:11, 167.83s elapsed (65535 total ports)
Nmap scan report for 10.1.0.10
Host is up, received arp-response (0.0094s latency).
Scanned at 2022-08-15 22:08:48 CEST for 168s
Not shown: 65534 filtered ports
Reason: 65534 no-responses
Some closed ports may be reported as filtered due to --defeat-rst-ratelimit
PORT   STATE SERVICE REASON
80/tcp open  http    syn-ack ttl 100
MAC Address: 34:C6:9A:00:16:D4 (Enecsys)
Read data files from: /usr/bin/../share/nmap
Nmap done: 1 IP address (1 host up) scanned in 168.05 seconds           Raw packets sent: 131198 (5.773MB) | Rcvd: 136 (6.115KB)
UDP port scan results for the gateway's IPv4 address:
Starting Nmap 7.80 ( https://nmap.org ) at 2022-08-15 22:12 CEST
Initiating ARP Ping Scan at 22:12
Completed ARP Ping Scan at 22:12, 0.06s elapsed (1 total hosts)
Initiating UDP Scan at 22:12
Scanning 10.1.0.10 [65535 ports]
UDP Scan Timing: About 2.24% done; ETC: 22:35 (0:22:33 remaining)
UDP Scan Timing: About 4.75% done; ETC: 22:34 (0:21:24 remaining)
UDP Scan Timing: About 8.86% done; ETC: 22:34 (0:20:14 remaining)
UDP Scan Timing: About 13.66% done; ETC: 22:34 (0:19:04 remaining)
UDP Scan Timing: About 18.69% done; ETC: 22:34 (0:17:55 remaining)
UDP Scan Timing: About 23.71% done; ETC: 22:34 (0:16:47 remaining)
UDP Scan Timing: About 28.74% done; ETC: 22:34 (0:15:40 remaining)
UDP Scan Timing: About 33.76% done; ETC: 22:34 (0:14:33 remaining)
UDP Scan Timing: About 40.70% done; ETC: 22:33 (0:13:01 remaining)
UDP Scan Timing: About 45.72% done; ETC: 22:33 (0:11:55 remaining)
UDP Scan Timing: About 50.75% done; ETC: 22:33 (0:10:48 remaining)
UDP Scan Timing: About 55.77% done; ETC: 22:33 (0:09:42 remaining)
UDP Scan Timing: About 60.80% done; ETC: 22:33 (0:08:36 remaining)
UDP Scan Timing: About 65.82% done; ETC: 22:33 (0:07:30 remaining)
UDP Scan Timing: About 70.85% done; ETC: 22:33 (0:06:23 remaining)
UDP Scan Timing: About 76.11% done; ETC: 22:33 (0:05:14 remaining)
UDP Scan Timing: About 81.13% done; ETC: 22:33 (0:04:08 remaining)
UDP Scan Timing: About 86.16% done; ETC: 22:33 (0:03:02 remaining)
UDP Scan Timing: About 91.19% done; ETC: 22:33 (0:01:56 remaining)
UDP Scan Timing: About 96.21% done; ETC: 22:33 (0:00:50 remaining)
Completed UDP Scan at 22:33, 1314.24s elapsed (65535 total ports)
Host is up, received arp-response (0.0027s latency).
All 65535 scanned ports on 10.1.0.10 are open|filtered because of 65535 no-responses
Nmap done: 1 IP address (1 host up) scanned in 1314.44 seconds           Raw packets sent: 131071 (3.676MB) | Rcvd: 74 (4.290KB)
2.2 The Web Interface
The default credentials for the web interface are admin/password. You can tell that the gateway is (c) 2009 as there is no way to change the admin password ;).
The following endpoints have been detected on the device: ...
