Cyberdeck Mount Thumbscrews.stl
Thumbscrew "heads" for the monitor holder to tension the swivel hinges and lock the holder at a specific height.
Standard Tesselated Geometry - 848.23 kB - 09/29/2022 at 12:20
Download
Cyberdeck UDOO Bolt case.stl
Case for the UDOO Bolt to sit in
Standard Tesselated Geometry - 290.12 kB - 09/29/2022 at 12:20
Download
cable chain link_flat.stl
Singular link base for the chain link style cable guide
Standard Tesselated Geometry - 175.86 kB - 09/29/2022 at 12:20
Download
cable chain link_top.stl
Singular link cover for the chain link style cable guide
Standard Tesselated Geometry - 31.14 kB - 09/29/2022 at 12:20
Download
trackball_top.stl
Top part of the trackball construction
Standard Tesselated Geometry - 123.91 kB - 09/29/2022 at 12:20
Download
trackball_bottom.stl
Bottom part of the trackball construction
Standard Tesselated Geometry - 101.84 kB - 09/29/2022 at 12:20
Download
Cyberdeck Split Keyboard.stl
Cases for the split keyboard; the top plate for the switches came from https://www.thingiverse.com/thing:3106566
Standard Tesselated Geometry - 148.32 kB - 09/29/2022 at 12:20
Download
Cyberdeck Monitor Mount.stl
Central monitor mount with hinge
Standard Tesselated Geometry - 36.41 kB - 09/29/2022 at 12:20
Download
Cyberdeck PSU case.stl
Case for the PSU portion of the build
Standard Tesselated Geometry - 124.59 kB - 09/29/2022 at 12:20
Download
Cyberdeck Chain Link central anchor.stl
Central anchor for the cable management chain link
Standard Tesselated Geometry - 94.71 kB - 09/29/2022 at 12:20
Download
Cyberdeck Monitor Clamp.stl
Four piece monitor holder with hinge
Standard Tesselated Geometry - 97.15 kB - 09/29/2022 at 12:20
Download
