Apple Ecosystem Build
A project log for Modular OTS Cyberdeck Creation Kit
A suite of printables designed around using (mostly) off-the-shell parts to make your own custom computing platform/ Cyber Deck/ Lapdock
sp4mSp4m 04/24/2023 at 20:220 Comments
The Prototype has issues getting the components to fit cleanly. This is a side effect of the solid body construction, and I have an elegant solution. I will call it the Lock Block.
On the left side of the chassis there is a set-screw that will push the orange block to the right, acting as a clamp to hold the keyboard in place.
On the right side of the trackpad there is a similar solution.
I also fixed the modular mounting holes, and eased up on device tolerance a bit.
I am going to print this "upright," so the peripheral channels on the right and left side can print cleanly without any support.
Let's try another print!
6h 40m with a .6mm nozzle, and a layer height of .4mm
Let's see!
