Did I actually Finish Something?!
A project log for Modular OTS Cyberdeck Creation Kit
A suite of printables designed around using (mostly) off-the-shell parts to make your own custom computing platform/ Cyber Deck/ Lapdock
sp4mSp4m 05/01/2023 at 17:140 Comments
The third print of the Apple Ecosystem Unified Input Chassis came out great! There are just a few important improvement opportunities, and I've already implemented them.
1. The Left Side Cable Access port was adjusted to print at an angle, using the 45 degree uneven hexagon style that I used for the decorative 'speed holes' on the bottom. This should let it print without supports!
2. The Track Pad Lock Block needed two points of contact with the main body to hold it straight. This means I need supports again, but I'm trying something new... built-in support!
3. Cable Management channels had slop  due to overhang, so I rotated then 45 degrees.
Looking Good, but I'm all out of white filament at the moment.
