![](https://cdn.hackaday.io/images/6676991666590550605.jpg)
The mane problem is the motor mount. Ideas converged on a simple rack mount. Plastic designs optimized for efficiency just aren't exciting. They all converge on a grid with walls chopped out to create open spaces. In this case, the circuit boards would be a sandwich under the motor. They're wider than the motor.
