Hackaday.io Hackaday.io
Sign up Log in
Valve Controller
Custom board to control motorized ball valve with 5V logic.
olekOlek
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
409
1
4
3
Team (1)
  • olekOlek
Join this project's team
completed project
hardware
Valvecontrol ttl logicboard
This project was created on 10/22/2022 and last updated 3 years ago.
Description
I have designed this board to control the specific 24V valve with 5V logic. It features LEDs to indicate the end positions which are also passed via 5V output from the board. The valve is controlled by connecting specific wires to 24V. It has also built-in aux switches to provide information when the end position is reached. The board is controlled by sending 5V signals to either close or open the valve. While the signal is transmitted it momentarily provides power to related input to the valve. The controller has isolated circuit controlling relays as well as Schmitt Trigger IC to debounce and square the aux outputs from the valve. The board was mounted on a din rail with 3D printed housing featuring din clip
Project Logs
Collapse
  • Assembly
    Olek • 10/24/2022 at 09:56 • 0 comments
    Assembled Valve Control board
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
qtron wrote 04/19/2023 at 16:08 • point
more info please.. much more!
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Valve Controller", please tell us the reason.
Send message
Remove Member
