The plan so far.
A project log for HBSound
DIY Sound Card for A home brew Computer
dave-collinsDave Collins 10/26/2022 at 03:290 Comments
So for starts I am building a rough bread board prototype, which i can control with a easy to program attiny88 dev board ( I use a cheep USB programmer as the usb ports on these are practically worthless.)  I can run a simple test program at the moment that sets the registers in the PSG (using the control logic on the bottom board (all HCT).  Next is to hook up the FIFO module, and get it to do write through:
After that is working, I will start work on a design to implement an adjustable clock, with interrupt generation as an option that can be used to set a sample rate based on a maximum of 32 kHz.  The basic diagram for the card is as follows:
The design is still fluid, but I am hoping once I get the kinks worked out of write through I should be able to proceed on to getting the TCM (Timer / Clock Module) finished.
