I've never used openscad in my life and the few shots i've taken at making a 3d printable cad designs have ended badly.. because i'm really bad at it. But I had an openscad and an idea...
The first gen cart enclosure up on thingiverse now used the 'ultimate parametric box' things openscad and a few of its remixes that let you put holes in the front plates and a lot of dirty hacks to the scripts to get 'useable' exported stl files making the modified openscad unusable and unpublishable...
a lot of wasted filament, filing, and sanding later and i had a 'working' desk drive.. i also modded the retroCART slot itself a little cause it was too tight a fit on my printer so i fudged in a little - uh whats the word - slack? shit whatever.
One side load cartridge drive made.. yay.
made carts for a usb wifi6 adapter, a too-damn-small 64gb usb stick i got for a chromebook but never used on it cause id lose it or break it, and an empty default sized one to measure with that i'll stick something in eventually.
so it works and usb3 and really does help me with my problem getting stuff plugged in and out and stuff
super yay!
but
hrm.. really want this to be a top load like the atari.. and look better...
and i still have ideas... ugh effort
luxotek
Scott G
Starhawk
Jenny List
