Prismatic Scara
A robotic manipulator based on a scara robot but adding two more linear degrees of freedom for the purpose of writing Chinese calligraphy
Public Chat
Prismatic Scara is an Open Source and printable robotic arm with four degrees of freedom. It has two rotations and two linear movements; one in the radial direction and the other one in the vertical direction. The radial direction doesn´t expand the C-Space of the robot (it has the same as a regular scara) but allows the brush strokes to be clean and fast. The vertical movement allows the brush to apply different pressure to get thin or thick strokes.
Update: the C-Space of the pristmatic is bigger than the C-Space of a regular Scara. This, due to the linear movement. It's expanded with lines of different slopes, but it leads to difficult poses to the manipulator that makes hard controlling it's cinematic.
The correction now is that the W-Space is the same as the W-Space of a regular Scara since it allows to work corectly with the cinematic of the robot.
Files .f3z link: https://www.thingiverse.com/thing:5733435
To do:
Software:
1) Test the code in python, wich contains the inverse kinematic of the manipulator.
2) Check that the serial communication (between python and arduino) is working.
3) Program in python the 8 basic strokes in chinese calligraphy.
Hardware:
1) Properly accommodate the wires in the robot. Some movements tangle the wires, this is a critical problem and must be fixed.
2) Improve the pieces of the brush, because they break easily, thus, must be replace often. This can be due to problems in design or because of quality of 3D printing.
VID_20221214_172510 (1).mp4
home and zero function
MPEG-4 Video - 24.08 MB - 12/22/2022 at 02:39
Download
VID_20221214_160349.mp4
Brush control
MPEG-4 Video - 2.34 MB - 12/22/2022 at 02:38
Download
Scaraprismatico.zip
Inventor CAD files
x-zip-compressed - 43.54 MB - 12/22/2022 at 01:24
Download
WhatsApp Video 2022-12-15 at 15.12.43.mp4
Show of the movement of the manipulator
MPEG-4 Video - 5.23 MB - 12/15/2022 at 19:15
Download
manipuladores_final.ino
Communication between python code and arduino
ino - 4.18 kB - 12/15/2022 at 19:06
Download
View all 6 files
  • 3 × Motor stepper nema 17
  • 1 × Motor servo MG995
  • 1 × Aluminum V-slot profile
  • 3 × 16 teeth pulley GT2 6mm
  • 3 × GT2 drive belt
View all 15 components
  • 1
    3D printing
    To manufacture the parts, a 3D printer is used, specifically the CR-10 printer, using the Cura 4.11 software with the following parameters:
    • Layer Height: 0.2mm
    • Nozzle: 0.4mm
    • Tree supports with 60° overangle
    • Horizontal expansion: -0.05mm
    • Material: PLA
    • Weight of material: 700 g
    • Infill: 20%
    The pieces corresponding to the bearings of the project, the rodtest piece is printed, so that the tolerances of the 6mm balls and the bearing tracks are adjusted, varying their horizontal expansion.
  • 2
    Assembly of pieces
    The assembly between the vslot profiles is carried out by means of localized blows normally to the section plane, in order to achieve a pressure joint without glue. The following image illustrates the assembly of the vertical bar that is the axis of the rotating base.
  • 3
    Assembly of bearings
    To assemble the bearings, the pieces are arranged in an aligned manner and the balls are inserted through the hole provided to load the bearing with balls. Also remembering to insert the closed band in the section arranged to achieve transmission with the shaft.
    Performing the same procedure for the lower section.
    In addition to a cover so that the balls cannot come out of the bearing. The second bar bearings can be seen below:
    Then the bars are linked as you can see in the image:
View all 7 instructions
