Definitely better viewing angles
A project log for Fixietube - Fake Nixie Tube displays
30ml jam jars turned into beautiful LED displays - nixietube like looking without the higher voltage fuzz
davedarkodavedarko 06/14/2016 at 16:144 Comments
So while I was in Austria for an installation the 3mm diffuse LEDs came in and I had to solder one of the left over boards together. The blue LEDs might need a diffuser as well andI still want them to turn off at night. Actually I could just fix that right now in software.
deʃhipu wrote 06/15/2016 at 07:19 point
That looks much better! Are you going to steampunk the plastic somehow?
davedarko wrote 06/15/2016 at 11:37 point
I kind of like the 60ies / 70ies vibe. What would you do to steampunk it?
deʃhipu wrote 06/15/2016 at 12:09 point
I guess paint with Brass Scorpion over Chaos Black base, and then drybrush with Skullcrusher Brass...
davedarko wrote 06/15/2016 at 12:55 point
all about that brass, he?
