32 Byte Diode PROM
I felt that a 16 byte diode PROM was too small. You cannot fit a program with a subroutine in 16 bytes. So I designed a 32 byte diode PROM, but unfortunately I could not get the auto-router to work. SO the answer is two 16 byte daughter boards:
![](https://cdn.hackaday.io/images/7965721671068707118.png)
Here is the schematic:
![](https://cdn.hackaday.io/images/2569091671068779091.png)
One nice thing is that the boards are stackable.
I will have to put back the page circuity on the mother board.
I have sent the PCB off for fabrication. Usually takes 5 or 6 days.
I have made a mistake with regard to stacking the boards. You cannot get 20 pin long headers, typically they are 10 pin headers, and you need a gap between them. Oh well!
I designed a PCB for the 10 long pin headers:
![](https://cdn.hackaday.io/images/4342871671087995119.png)
But I am not getting them made until I use up the previous design.
AlanX
