16x8 bit Diode PROM
A project log for Hardware Controlled 4 bit CPU
A hardware controlled 4 bit CPU based on lessons learnt from the TD4 and the CHUMP CPUs
agpcooperagp.cooper 12/14/2022 at 04:530 Comments
Diode PROM
Here is the Diode PROM:
The "CS" DIL switch allows up to 8 PROM cards. I am only using one this time.
The board layout is as follows:
Laying out the diode PROM is quite time consuming, and near the limits of the Easy EDA auto-router. So I will add the CPU design to the diode PROM schematic and PCB design.
AlanX
