photoscan and repair hatch button
repair a citroen c3 pluriel hatch button with the help of photogrammetry and a CNC cut mold
0 followers
Having a dated car and finding spare parts can be difficult, especially when such a simple element as a hatch button is molded in a meter-wide, monolithic and model-specific plastic part.
I couldn't hope to find this part in a scrapyard as they probably would have sold the whole rear window with it.
Having discovered photogrammetry with meshroom a couple of month ago, i decided to give it a try to replicate the shape of this part.
boutonc3.nc
gcode c3 pluriel rear button 2mm drill bit
Network Common Data Form (NetCDF) - 205.91 kB - 12/14/2022 at 22:49
Download
  • 1
    Scan of the button
    To begin, I took several picture (29) of my rear hatch button with my smartphone (moto g7 play) with the "manual" settings and imported them in meshroom.
    I wasn't expecting much from such a featureless / glossy plastic but the results turned up to be really good.
  • 2
    Modelling the button in fusion 360
    After a bit of mesh cleanup/alignment in Blender, I imported it in fusion 360 and started surface modelling . I tried to match the surface of the mesh as much as i could
  • 3
    Creating the mold
    I did a boolean operation to create the negative shape of the mould
View all 8 instructions
