Introduction
In today’s world, health monitoring is a major issue. Patients suffer from serious health problems as a result of a lack of proper health monitoring. There are many IoT devices available these days to monitor a patient’s health over the internet. Health professionals are also using these smart devices to keep tabs on their patients. IoT is rapidly revolutionizing the healthcare industry, with hundreds of new healthcare technology start-ups using patient health monitoring system
In this project, we will create an IOT-based Health Monitoring System that will record the patient’s pulse rate and surrounding temperature. This system not only record these data but also update them in IOT platform. The IOT platform used in this project is Thing Speak. Thing Speak is an open-source Internet of Things (IoT) application and API to store and retrieve data from things using the HTTP protocol over the Internet or via a Local Area Network.
We have already done some similar projects you can view them by clicking the following link
IOT BASED PARALYZED HEALTH CARE MONITORING AND FACILITATION
PCB Manufacturer
PCBWAY is quite professional in the field of PCB manufacturing; you can try their services at extremely low prices, Only 5 dollars for 10 PCBs , besides this the new members also get a 5 Dollars bonus.
You can now upload the Gerber File to the Website and place an order. The PCB quality is superb & high standard. That is why most of people trust PCBWAY for PCB & PCBA Services.
You Will get FREE prototype pcb from PCBWAY. So do not be late to register and place your first order from PCBWAY
If you want to order pcb from PCBWAY . CLICK IN THE LINK BELOW:
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/06/728x280-1.jpg?resize=728%2C280&ssl=1)
Some Sample PCB ‘ S From PCBWAY
![](https://i1.wp.com/electronicsworkshops.com/wp-content/uploads/2022/09/303800332_403671735247930_7000885754973015080_n-1024x768.jpg?ssl=1)
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/09/305225115_617327676688843_4865018072250269254_n-1024x768.jpg?ssl=1)
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/09/303386222_1195812481151463_6368872295324426767_n-768x1024.jpg?ssl=1)
![](https://i2.wp.com/electronicsworkshops.com/wp-content/uploads/2022/09/s11-1024x768.jpg?ssl=1)
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/09/s13.jpg?w=760&ssl=1)
Manufacturing Files
If you don’t want to assemble the circuit on breadboard and you want PCB for the project, then here is the PCB for you.
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/11/Top-Pat-605x360-1.jpg?resize=605%2C360&ssl=1)
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/11/Bottom-Pat-603x360-1.jpg?resize=603%2C360&ssl=1)
Gerber Files
Download gerber files
Gerber_PCB_Patient-Health-MonitoringDownload
Bill Of Material
SN | COMPONENTS NAME | DESCRIPTION | QUANTITY | ![]() |
1 | Arduino Nano Board | microcontroller | 1 | https://amzn.to/3EBaQFT |
2 | LCD Display | 16x2 LCD Display | 1 | https://amzn.to/3hXYRdV |
3 | Potentiometer | 10K | 1 | https://amzn.to/3tX7vMD |
4 | ESP8266-01 | Wifi Module | 1 | https://amzn.to/3EwkTfD |
5 | Pulse Sensor | PulseSensor.com | 1 | https://amzn.to/3OAxxPb |
6 | LM35 | Temperature Sensor | 1 | https://amzn.to/3XvVaN2 |
7 | Connecting wires | jumper wire | some | https://amzn.to/3tX7PLl |
8 | Breadboard | Normal | 1 | https://amzn.to/3Vlefzw |
9 | 2K Resistor | tht | https://amzn.to/3EudLQO | |
10 | 1K Resistor | tht | https://amzn.to/3V5Yblo | |
11 | LED 5mm | Any Color | 1 | https://amzn.to/3AHaTih |
Block Diagram
This is a simple block diagram demonstrating the IoT Based Patient Health Monitoring System with ESP8266 and Arduino. BPM and environmental temperature are measured by the pulse sensor and the LM35 temperature sensor, respectively. The code is processed by the Arduino and displayed on a 16*2 LCD display. The ESP8266 Wi-Fi module connects to the internet and sends data to an IoT device server. The IoT server used here is Thing speak. Finally, the data can be accessed from anywhere in the world by connecting to the Thing speak channel.
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/11/IoT-Based-Patient-Health-Monitoring-System-using-ESP8266-Arduino-1.jpg?resize=628%2C324&ssl=1)
What is a Pulse sensor?
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/11/11574-01.jpg?resize=600%2C600&ssl=1)
A pulse wave is the change in the volume of a blood vessel that occurs when the heart pumps blood, and a detector that monitors this volume change is called a pulse sensor. The Pulse Sensor is an Arduino-compatible heart-rate sensor. Students, artists, athletes, makers, game and mobile developers who want to easily incorporate live heart-rate data into their projects can use it. It essentially combines a basic optical heart rate sensor with amplification and noise cancellation circuitry, allowing for quick and easy pulse readings.
![](https://i0.wp.com/electronicsworkshops.com/wp-content/uploads/2022/11/pulse-sensor-lifeispreety.com_-300x188-1.jpg?resize=300%2C188&ssl=1)
Pulse sensor top and back view
There is also a LED in the center of this sensor module which helps in detecting the heartbeat. Below the...
