Case hacking part 1.
A project log for Pi Zero PC by Bay Networks (The Pikelet)
I acquired a great little EN104 Bay Networks 'Netgear Hub'. I decided to re-purpose it to house a little Pi Zer0.
tinkerzonetinkerzone 12/13/2016 at 04:120 Comments
So the first part of the case mod was to make the HDMI port accessible. I'm pretty disappointed with the result as i failed to follow the old 'measure once, cut twice rule. A series of 4 holes were drilled with a 1/8th drill, then filed into the shape of the port. One hole was placed to far to the left, and another drifted down the case, leaving an opening slightly to big. The micro HDMI to HDMI adapter covers most of the hole, but some form of repair may be needed at a later point.
