It's Alive!
A project log for Eldricht : The Line Following Robot
Eldricht is a small robot designed to follow a line, take commands from an IR remote.
amorphousengineerAmorphousEngineer 12/30/2016 at 20:580 Comments
Good news everyone! I received the boards from OSH park! I soldered on some components and tested the ATMEGA 328P-AU. I currently am running a blink at 1Hz using Atmel Studio. Seriously considering adding debug wire...
I have found the following design problems:
