esmodio is an automation device. The main features are;
-12V-24V Supply voltage. Digital input and outputs are working based on the supply voltage.
-The device has over current protection with resettable fuses
-Analog input side selectable 0-3.3V, 0-12V or 0-24V or any
-MOSBUS ready on the device. 0x01, 0x02, 0x03, 0x05 and 0x15 function codes are working
-Standard 3.81mm pluggable connectors are used.
esmodio can be useable for;
-Test platforms, test benches
-Plant automation
-Generic automation
-PC controlled platforms
-Data acquisition system
-Data logging
