Hi everyone, today I am going to unbox and assemble the Crowbot Bolt an open source programmable Smart Robot Car.
CrowBot BOLT is an open source smart programming car powered by ESP32 chip. It has a wealth of sensors (such as a light sensor, ultrasonic sensor, and line Tracking Sensor), comes with Wifi and Bluetooth functions, and can meet a variety of programming environments like Letscode, Micropython, and Arduino. It can quickly realize functions such as light tracking, line tracking, obstacle avoidance, remote control, and light show. As an entry-level STEAM educational robot, the cool and cute BOLT makes robot programming learning and teaching easy and fun.
Order Crowbot Bolt from here: https://www.elecrow.com/crowbot-bolt-programmable-smart-robot-car-steam-robot-kit.html?idd=3
Where To Buy
This cute little smart car was a birthday gift to my son from www.elecrow.com.
He was very excited to unbox, assemble and program it using the drag and drop programming language. He named it - Lily.
You can buy this cute, creative, programable, multitasking and educational smart robo-car for just $34.90 from https://www.elecrow.com/.
I have provided the link in the description below.
Order here: https://www.elecrow.com/crowbot-bolt-programmable-smart-robot-car-steam-robot-kit.html?idd=3
Unboxing
So, this is what came in the mailbag. I was super excited to open the box and see what's inside.
CrowBot has features like Infrared Tracking, Light following, Bluetooth/WiFi, Buzzer, Ultrasonic obstacle avoidance, Four RGB LEDs, Programmable IR remote control and Double wheel front drive.
The box is very lightweight and contains all the components that you need to create this robo-car.
So, this is what's in the box.
The items on my right are the ones that will assemble into the robo-car.
And the items on my left will assemble into the programmable remote control.
The only additional item that you need is 6 x AAA batteries, 4 for the car and 2 for the remote.
Everything comes pre-soldered, all you have to do is, spare 30 minutes of your time, sit down and assemble it.
CrowBot uses acrylic plate as the shell, and the assembly is simple, just align the slots and tighten the screws to complete the build.
The Package Includes
  • 1x Chassis
  • 1x Ultrasonic Sensor
  • 1x Battery Holder
  • 2x Wheels
  • 4x M3*8mm Screws
  • 2x M3*5mm Copper Column
  • 2x Side Acrylic Plates
  • 1x Front Acrylic Plates
  • 1x Screwdriver
  • 2x 4 Pin Crow tail Cable
  • 1x Type-C Cable x1
  • 1x Infrared remote control
  • 1x Instructions & Line Track Map
Quick Look
Before assembling the components let's have a quick look at the chassis of the car.
The top side has 2 x geared motors, an ESP32 Micro Controller, an off-and-on switch, a Reset button, 2 x light sensors, IR Receiver for the IR Remote  and 4 x female pin headers for the Ultrasonic Sensor.
The bottom bit has the omni directional wheel, 2 x Line Following sensors, switches to toggle between BT and WiFi, USB Type-C interface for loading programs and 2 x I2C interface which can be connected to 150+ Crowtail modules making it highly scalable.
Assembling The Car
Alight, now let's start putting the bits and pieces together.
I first connected the "Battery Holder" to the Chassis. Then, I connected the two female standoff spacers to one side of the "Side Acrylic Plate".
Next I slided the chassis into the side plate and attached the front plate to it. Once I was confident that all the bits are aligned to the correct holes I attached the 2nd side plate to the chassis, and tightened the screws to complete the setup.
Next, I connected the Ultrasonic Sensor to the female pin headers on the chassis. CrowBot's ultrasonic sensors not only avoid obstacles, but also emit colorful RGB lights. The unique design gives it more creative possibilities.
Next, I connected the two wheels to the chassis, that's it all done.
So as you can see, the middle of the front bit has the Ultrasonic Sensor with two Light Sensors on...
