Designed to experiment
Code • GNU General Public License v2.0
What is this ?
Hi, here is a shield for Arduino uno adapted to be plugged on Lego.
Shield Arduino Uno Compatible avec les blocs de construction LEGO
This shield for Arduino Uno is a tool for Lego and programming enthusiasts. It allows you to easily connect your Arduino Uno to Lego bricks, opening up endless possibilities for creating robots, automated devices and other experimentation.
With this plug-and-play solution on Lego bricks, you can easily control your creations using 6 potentiometers and 5 buttons. Ideal shield for programming beginners and experts. Don't wait any longer to bring your creative ideas to life with this Arduino Uno shield for Lego!
For example, you can use this shield as a control surface for your UNO.
Once the 20mm "header pin male" is welded, you can connect the arduino to the bottom of the shield, the "jumpers" come to connect on it, the lego come this plugger around the object thanks to the holes in the format identical to Lego.
Your feedback is welcome to improve the tool. Thanks
Necessary component:
- Arduino Uno x1
- Potentiometer 10K x 16
- btn push x 5
- Header pin male
- PCB x 1
Share your project with this shield
2020 v-1.0.1
Designed by Make and play .
berru-g
Open Technology
Akshay Pradheep
Alex Anderson
If you want to use an Arduino Uno with Lego, there are a few options for shields that you can use. One popular option is the "Arduino Motor Shield" which can control up to four Lego NXT motors or two Lego RCX motors.
Another option is the "Bricktronics Shield" which is specifically designed to connect an Arduino Uno with Lego NXT or EV3 sensors and motors. This shield includes support for I2C communication, so you can use it to communicate with other I2C devices as well.
If you're looking to build your own custom Lego-compatible electronics, you may also want to consider the "Arduino Brick" by Dexter Industries. This board has a built-in Lego-compatible connector and includes several I/O pins that you can use to connect to other sensors and actuators.
Overall, there are several options available for using an Arduino Uno with Lego. It depends on your specific needs and what you're trying to build. https://denvertowncarservicesdia.com/
