Microkeyboard
MicroKeyboard is a small customizable keyboard/mouse. Based on ArduinoMicro.
Public Chat
Starting from
$20.00
chris_maker_ has 2 orders / 0reviews
Ships from Italy
This project was sponsored by PCBWay.
Based on ArduinoMicro, it allows you to choose the function to be associated with each single key, including encoder and thumbstick.
On board the board you'll find a two-axis thumbstick with push button, a push button encoder, and five Cherry MX-style buttons. Each of the 5 buttons has a led connected to a PWM output of the micro in order to create an infinity of light effect.
Also you will find a connector with the remaining free pins of the micro including I2C and UART port.
The SCL and SDA pins are pulled-up from R8 and R9 (10k). If you want to interface a device via I2C or UART port that works at 3.3v you will need a level adapter.
Remember Arduino Micro works at 5v, if you decide to power the board from the external port remember that VIN must be between 7 and 12v!
Portable Network Graphics (PNG) - 110.83 kB - 02/05/2023 at 17:37
Preview
Keycode.txt
plain - 17.91 kB - 02/05/2023 at 17:37
Download
Layout.txt
plain - 572.00 bytes - 02/05/2023 at 17:37
Download
  • 5 × Cherry MX1A
  • 1 × Joystick (PS4 model)
  • 1 × EC11 Rotary Encoder
  • 2 × R 10k (0805)
  • 2 × C 0.1uF (0805)
View all 8 components
